Clutch
Old Apr 9, 2005 | 01:33 PM
monkeyinajar's Avatar
Default Clutch
I too suffer from a harder to shift shifter. It doesn't like to go into neutral even close to as easy as before I had changed the clutch out. Before, I had no slack in my cable. When I redid my clutch I put slack in the cable like most bikes require so you don't prematurely wear the clutch out.... do I have too much slack? Should there even be any slack on the DS?
Old Apr 9, 2005 | 03:08 PM
Freakneh's Avatar
Default Clutch
I probably have about 1/8 of an inch of slack in mine...works just fine.
J.
Old Apr 26, 2005 | 10:37 PM
NickDS650's Avatar
Default Clutch
Well thanx to Squacher for the honda cable info. I just got word from Motion Pro about a clutch cable for the DS650 - we "have the Terminator clutch cable for the 00-04 DS650 Bombardier available. The cost is $51.90" Now thats better than the Bomb stock clutch cable at $80 which is BS since i called the dealership one day and it was $45 and then the next day i call to order it changes to $80, BS man BS!
Old Apr 27, 2005 | 12:15 AM
Bomberboy's Avatar
Default Clutch
I wish i would of known about that along time ago. Ive went through two clutch cables! Boy was that expensive. Oh well you win some you lose some as i always say.
Old Apr 27, 2005 | 02:25 AM
  #15
DuneMe's Avatar
Default Clutch
Mine broke right at the slug down by the actuator arm. I need a spare. Trips are too well planned to get spoiled by not having a clutch cable.
Anyone got the Motion Pro Part Number?
Honda part number?
Old Apr 27, 2005 | 04:22 PM
  #16
NickDS650's Avatar
Default Clutch
yea DuneMe thats where mine broke also. The Honda Motion Pro part # like Squatcher said is 02-0164, but talking to the Motion Pro guy i dont think i want to go that way, he said somethin about having to make it fit lol and i'll steer clear of rigging up an important cable
Old Apr 27, 2005 | 11:02 PM
  #17
NickDS650's Avatar
Default Clutch
the word from Motion Pro on the subjet...
"02-0164 fits Honda XR200/250R 1984-1985, XL250R 1984-1987. The difference between the two is the bottom fitting. If you use the cable above you would be missing a key component-the lower barrel. The 02-0164 uses a pear fitting where the 01-1021 uses a barrel, so you'd have no way to connect it unless the cable was rigged in an unsafe fashion. I cannot recommend the use of the 02-0164 cable for the DS650 based on the information I have here. If you wanted to purchase it you would be doing so at your own risk... "
buddieboy
Dec 9, 2016 05:50 PM
tysonbully
Sep 28, 2015 02:30 AM
jbrewster94
Sep 23, 2015 04:16 PM
roy.hawkins3@gmail.com
Sep 11, 2015 02:35 PM
cdstang
Aug 31, 2015 07:52 AM
