Starter
Old May 10, 2005 | 12:55 PM
DsDemonKid's Avatar
Default Starter
i thought so too...must b using something else.. more info
Old May 10, 2005 | 02:33 PM
crazypainter's Avatar
Default Starter
Bomberboys is an Alba labled cdi, probably pro-com. Mine is a Woods, no problems with it
Old May 10, 2005 | 03:48 PM
biggerisbetter's Avatar
Default Starter
probably shouldnt be using pump-gas with a CDI that advances 18 degrees. It sounds like the reason for the backfire is the pre-ignition, and as you all know the higher the octain the better pre-ignition tolerances. JMO
Bigger.
Old May 10, 2005 | 04:37 PM
Oldmanracing's Avatar
Default Starter
When they say advanced 18 degree's, I think they mean 18 above set timing.
Set timing is 10 degree's and the advance of 18 would mean a total of 28 degree's.
The factory timing is a total of 26 degree's.
All aftermarket CDI's draw more voltage. If your battery is not charged to the high side, you may have problems. The starter draws the major voltage and the remainder to the ignition.
If battery is low the ignition may not fire everytime it should. This loads the motor and when it does fire it may cause motor to suddenly stop or slightly backup. This is not good for starter.
Unless you ride your quad daily, you should charge your battery often. Or have a battery tender, so it is always ready to go. If my DS does not start within the first 5 seconds, I hookup the battery charger and come back in 30 minutes. I run a total of 30 degree's with a set timing of 14 degree's. 2001 with same starter.
Good battery and jetting is critical to DS's.
Aftermarket ignitions are all getting better. But they are not stock. If you want the extra performance, then there will be extra maintenance. Half the fun of modding a motor is taken care of it. If you do not like to do mainteance, then leave it stock and eat dust.
Old Sep 15, 2005 | 11:45 PM
  #15
Dingo2's Avatar
Default Starter
I've been running a SRP CDI (Pro-Comm I think)..for about 9 months..No problems yet...but just the last few times I've started her up, its been kinda making a weird noise ..backfire, not sure, but it sounds like the starter. I have a Odessey 545 battery, buts its now about a year old. Could I be having or starting to have some of the same problems I've been hearing about? Should I put the stock CDI back on? How do I know if I've damaged anything? Also, would a CDI like a Vortex give me the same problems?
Old Sep 16, 2005 | 12:30 AM
  #16
CountryJoeGlass's Avatar
Default Starter
Dingo2 you should have no problems running the vortex CDI. I run the vortex CDI with no problems.
Old Sep 16, 2005 | 02:39 AM
  #17
Mrneg9's Avatar
Default Starter
Same problem here. I was running the procom CDI. I went back to stock for a while and then went with a Ron Woods CDI and to this day have not had any problems.
Old Sep 16, 2005 | 04:26 PM
  #18
Dingo2's Avatar
Default Starter
Mrneg9...whats the possibility of any damage and how might I know. How long was yours making that noise before you switched back to stock?
Old Sep 16, 2005 | 05:16 PM
  #19
Mrneg9's Avatar
Default Starter
Mine once in a while backfired which made a popping sound in the air box under the seat. It did it several times over the course of 6 months. The thing here is I only ride on Sundays with my son so it took a while to damage my bike. One day we went out to ride and my bike stalled. When I went to start it back up it made a grinding sound when starting but then it stopped. I started it up after that about three more time and every time I heard the grinding noise. I got it home took the side case of the motor and found that one of my gears was bent and I tore up my sprag clutch. The parts ended up costing me a round $500.00 and I did the fix myself. I will tell you this if your aftermarket CDI makes your bike start funny especially backfiring or popping take it off immediately or it will for sure damage your motor. Alot of guys don't know it but the motor on your quad is the same as the BMW Funduro. I ended up getting my sprag clutch from them for under $100.00 when all the Bombardier dealers wanted between $275.00 and $340.00.
Here is a link to their site.
http://www.ascycles.com/Illustrated_catalog/F650Funduro(97-99)/catalog_frameset.html
If you go to Diagram #12 you will see the parts that got damage on my bike from the Procom CDI.
Parts # 11,12,15 and 20.
  #20
Default Starter
When was the last time you put dielectric grease on the battery terminals and the reg/recitifier connections. Maintenance is important. CDI's usually fail during its burnin range. First thirty days.
Also; what rpm does your engine idle at? Stay closer to 1400rpm. Butterfly covers low speed oriface and can cause the motor to slighly load and backfire.
Johnny Mac
Aug 15, 2019 03:13 PM
Lucas Bohanan
Sep 29, 2015 01:16 AM
wrencher82
Sep 28, 2015 10:02 PM
kbazzy
Sep 26, 2015 11:26 AM
95scramblerruben1033
Sep 23, 2015 06:29 PM
