This was an interesting find!
Old May 10, 2005 | 06:26 PM
busmechanic's Avatar
Default This was an interesting find!
$80
Old May 14, 2005 | 01:46 PM
DaBomb650's Avatar
Okay, I pulled the side cover. Every thing is there, I pulled the drive gear, thrust washer impeller and shaft. There is no sign of wear anywhere. The only thing I can find, there is a little play in the drive gear where it "snaps" over the drive pin. If I pull on there gear until it stops, put the pump cover back on, and push the shaft all the way against the thrust washer, the impeller DOES rub the cover.
If I remove the pump cover, push the drive gear on as far as it will go, put the pump cover back on, push the drive gear against the thrust washer, the impeller does NOT rub.
I am thinking I need a new drive gear. What are your thoughts and/or ideas.
After removing the impeller and upon closer inspection in better light, it is worn. The wear coincides with the wear i=on the inside of the pump cover.
Should I replace the impeller, cover AND drive gear? Is the gap between the pump cover and the impeller that critical?
Nondem
Feb 22, 2020 12:20 PM
4464
Aug 21, 2015 01:46 AM
KingDingalling
Jul 29, 2015 10:55 AM
Nondem
Where to Ride
Jul 23, 2015 07:38 PM
RticKwad
Jul 21, 2015 03:00 PM
