Leak free sleeves
Old 03-31-2006, 10:03 PM
H's Avatar
H
H is offline
Default Leak free sleeves
All right I'm gonna let everyone in on the secret way to have a leakfree sleeved big bore with the copper gasket-PL400 constuction adhesive, it seals but lets things move a smidgen with expansion. You can also vary the compression with the bead thickness. Just a little FYI[img]i/expressions/face-icon-small-smile.gif[/img]
Old 04-01-2006, 09:37 AM
choosetolose04's Avatar
Old 04-01-2006, 10:45 AM
crazypainter's Avatar
Whats that smell? Oh, its BS[img]i/expressions/face-icon-small-wink.gif[/img] We used Polygrip because it was more resistant to liquids.
Old 04-01-2006, 12:24 PM
DSNUT's Avatar
You may be on to something here. The trouble with construction adhesive is that it is only flexible for a few months. Vulkum might be a better compound. Being constructed of high solids will allow it to handle the higher compression engines with years of flexibility. Good thoughts, all! [img]i/expressions/face-icon-small-wink.gif[/img]
Old 04-01-2006, 07:07 PM
thebigshow's Avatar
H, get rid of that copper gasket and get the triple layer by cometic, then u dont have to use sealant..[img]i/expressions/face-icon-small-wink.gif[/img]
Old 04-01-2006, 08:55 PM
Don't you have to eliminate the o-ring to use the cometic?
Old 04-01-2006, 09:37 PM
thebigshow's Avatar
No, quite a few of us have used the gasket without taking out the o-ring...im running over a year with mine with the 13 1/2 to 1 piston, several of the guys are running big shots of nos with it also without a failure yet.....but time will tale...
Old 11-15-2006, 08:19 PM
shmee's Avatar
john here is a good thread about the copper gaskets[img]i/expressions/face-icon-small-smile.gif[/img]
Old 11-15-2006, 10:15 PM
Old 11-15-2006, 10:22 PM
Goodsound's Avatar
Set a New OEM chassis 4 stroke national record on his OMW DS855 - 3.93 !
Whats all this talk about? John told me that he was at, and going to stay 11.5:1 stock bore. Why would he need a copper gasket? Did I miss something?
Quick Reply: Leak free sleeves
