milky oil ?
Old Aug 16, 2006 | 03:51 PM
maxxedouty's Avatar
Default milky oil ?
do a compression leak down test, listen for air escapeing.
Old Aug 16, 2006 | 03:54 PM
bombrider04's Avatar
Default milky oil ?
I would spend more money into my engine but ordred my renegade a few weeks ago and have to save every penny for when it comes in hopefully to pay cash...I need to shed some weight but I ride trails so I need the extra protection but can prob save on rotating mass
Old Aug 16, 2006 | 07:16 PM
ds650ctracing's Avatar
Default milky oil ?
Thank you all for the replys, I will get back with you when I take out the water pump seal tonight. Not running alky or nos, I currently still running the stock carburetor but have a tm45 on order, both spark plugs looked fine when I pulled them, but I can tell you that both the exhaust valves were the color brown like dirt or clay ? Also there was a medium amount of carbon buildup on the cylinder head and piston top.
Old Aug 16, 2006 | 07:55 PM
v2rider's Avatar
Default milky oil ?
Look at my pics and that might help. Did it get swamped ever?? I seen its a 200?. So i couldnt tell if its brand new or not. If not, money says it was swamped
Old Aug 16, 2006 | 11:31 PM
  #15
Default milky oil ?
I pulled the clutch cover & found the water pump shaft was badly worn out and both the o-ring type gaskets were very loose fitting the shaft, so I ordered all new impeller, shaft, seals, o-rings, gasket (approx.$50) Thanks for all your advice would not have found the problem without the can-am group.
p.s. I will report when I get everthing put back together.
Old Aug 17, 2006 | 01:37 AM
  #16
Default milky oil ?
there are some really smart guys on here and you will learn alot from reading the issues that people have good luck and hope thats all that is the problem...I am sure you aren't stupid but flush out all the stuff and if you are looking for a good antifreeze rockymountainatv.com sells engine ice which is biodegradable and is supposed to cool the engine 50 degrees better then antifreeze I love the stuff and seems to be doing the job...when you get a chance show some pics of the beast lol
fatholly I took off the ventline which was causing some of my problems and rejetted and got it dialed in and it really seemed to wake the ds up alot more thanks alot I appreciate it.Brett
Njrider1230
Jul 29, 2023 05:16 AM
shimley501
Jan 28, 2007 09:46 AM
EdgeRacing
Sep 5, 2005 11:51 PM
didididididi
May 23, 2004 06:08 PM
WIscrambler
Oct 27, 2002 05:48 PM
