engine vent hose filter
Old Feb 18, 2007 | 01:57 AM
pugads650's Avatar
Default engine vent hose filter
im getting rid of my airbox and i have no where to stick vent hose that comes from engine case i heard i can get filter but i cant find anything that small any help will be greatly appreciated thaks.
jonathan
Old Feb 18, 2007 | 05:44 AM
DuneRider650's Avatar
I ride a little here and there......
Yes, there are filters that small. Check dennis kirk they have them listed....they are small UNI's (look like K&N's)
Old Feb 18, 2007 | 09:38 AM
KaylasDaddy's Avatar
Has been riding one thing or another since I was 11 years old.(31 years).
go to Pep Boys or Autozone & go to the performance area. you can find a paper/metal or stainless steel. both run about $10. you will have to "sleeve" your existing hose with the next size bigger but it will work fine. with the stainless filter if you have any blow by you can clean the filter out. i ran mine up ti the top of my shrouds... or to the top of the baja lights.
Old Feb 18, 2007 | 12:01 PM
DSengineer's Avatar
Has been here a long time!
Better yet skip the messy filter all together. Pick up about 6ft of hose and run it up and over your radiator, around your oil tank and down through the bottom of the frame between the a-arms. No mess to deal with.....
Old Feb 18, 2007 | 09:10 PM
MRDS650's Avatar
Canadian and Proud of it !!!
I use a small K&N filter that I bought at a parts store. I ran the hose up beside the tube from the carb to the air filter. Keeping it up here keeps it out of the dirt and water. I also cut up an old outerwear to cover the little filter.
Old Feb 18, 2007 | 09:33 PM
pugads650's Avatar
do you have a part number for this filter i cant find it anywhere thanks for the help.
jonathan
Old Feb 18, 2007 | 10:34 PM
BigWaynester's Avatar
I am with DSengineer~unless you are in mud all the time where your hose gould get plugged, I don't think you need a filter, it blows out not suck in. I have used no filter on the breather tube on any of my quads.
Old Feb 19, 2007 | 12:47 AM
MRDS650's Avatar
jonathan
I had to look threw some old bills, but i think the part # is 62-1010 which should be a K&N part number.
lightninboy
May 16, 2021 09:52 PM
KimSJoh
14
Jul 18, 2015 07:20 PM
rcappie4
Jul 10, 2015 04:54 PM
cSchwartz
Jul 9, 2015 02:43 PM
D-Hagz
Jul 4, 2015 02:19 AM
