Vortex Problems
Old Feb 22, 2007 | 03:43 PM
DSengineer's Avatar
Has been here a long time!
Default Vortex Problems
My Vortex has always made a humming sound whenever the ignition is on. I just figured it was normal. Sounds very similar to a set of low frequency switching capacitors and can be heard within a few feet of the unit.
Are you guys saying this is NOT normal and it should not be making any type of sound? The unit has never given my any problems, but I am probably going to check out the ground on it.
Old Feb 22, 2007 | 03:57 PM
FatHolly's Avatar
My stocker never made a sound and my Vortex doesn't either.
Old Feb 26, 2007 | 11:28 PM
ERBEDS650's Avatar
Well the Vortex is Fried, CHECK YOUR GROUND GUYS!!!!!!! Got a RWR CDI coming in, Im getting the dyno done as soon as it comes in, I was going to to the stock CDI but it hit the rev limit too quick.
Old Feb 27, 2007 | 04:33 PM
DSengineer's Avatar
ERBE,
Where was your ground problem located? I moved my Vortex over to my other DS that I was running the stock CDI but it still humms. I either have two DS's with ground problems or just a noisy Vortex.
Old Feb 27, 2007 | 08:16 PM
  #15
ERBEDS650's Avatar
I had to move the ground from the subframe to the main frame, made a new ground strap.
Old Feb 28, 2007 | 11:36 AM
  #16
AZSAND's Avatar
THAT!!!!!Sounds down right sexy!
Good move i even make an extra strap too the motor.it is important.!!!!![img]i/expressions/face-icon-small-wink.gif[/img]
Old Mar 1, 2007 | 12:33 AM
  #17
DSengineer's Avatar
Where on your subframe was your ground strap originally? On my 04's the factory ground strap is just above the chain roller on the peice of flat metal that is welded to the shock mount. So technically its not on the subframe
greg74
Sep 10, 2019 03:03 PM
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
