KMS EFI fuel pump specs
My setup consists of
Aprilia Pegaso 650 IE 2x34mm dual throttle body (overbored to 2x36mm),
2 x Sagem high impedance injectors (150cc/min),
a pressure regulator 1-8 bar (variable) with gauge,
Megasquirt v2.2 EFI controller (fuel only),
Sensors (TPS, MAP, MAT, O2, CLT, Baro),
High pressure fuel hoses.
I need a fuel pump (150LPH/3.5-5bar)
and stator rewinding or F650GS stator (400w) later on.
Thanks guys,
NickDS650 maybe KMS doesn't want to reveal the pump's brand & model. It is somehow expected. I respect that.
I have the specs of the FI F650GS fuel pump (150 LPH / 50.7 psi = 3.5 bar) which shares the same motor but,
I am not really sure if the flow rate and/or pressure is enough for a tweaked motor like mine.
As long as I have an adjustable fuel regulator, I could go as far as 5 bar fuel pump and regulate it in 3.5 bars.
That means I will get 5 - 3.5 = 1.5 bars of pressure in return line (to fuel tank).
Is this normal return line rate ?
Is there a schematic of the KMS fuel lines assembly, because I am wondering where to connect the return fuel line.
Normally it connects to the fuel tank on a dedicated hose but I only have one petcock. [img]i/expressions/face-icon-small-wink.gif[/img]
The other solution is to connect it back to the low pressure circuit, just before the pump, using a Y connector.
What is the case with your KMS systems ?
