backfire...
Old Jul 1, 2008 | 03:38 AM
Swaie's Avatar
Default backfire...
Can the mods make this video a sticky!!!
<div class="FTQUOTE"><begin quote>Originally posted by: OMR
<a target=_blank class=ftalternatingbarlinklarge href="http://video.aol.com/video-detail/technical-demo-on-bmw-f650-valve-adjustment/859299288
">http://video.aol.com/video-det...tment/859299288
</a>
OMR</end quote></div>
Old Jul 3, 2008 | 01:30 PM
800vtwin's Avatar
Default backfire...
jetting a carb is totally throttle position dependant. If you have a problem at closed throttle then thats where your problem is. Leave your needle & main alone.
Valve adjustment will not cause problems. (if there loose- they're noisy, if there tight- you'll eventually burn your valves, dry your seals, burn oil, & be hard to start or idle, have low compression)
Muffled pops in the exhaust is too rich of a pilot jet. Drop down 1 size, test and possibly drop another size.
(A loud pop in the exhaust is way too rich. A loud pop from the intake is too lean.)
Old Jul 3, 2008 | 03:55 PM
SilverBomb's Avatar
SilverBomb has got an Addiction!
Default backfire...
</a>
I love towards the end when he says he has 42000 miles on that bike. Thats Awesome, it says a lot about these great Rotax motors.
pavwa
Jul 31, 2014 04:06 AM
350raptor350
Dec 28, 2007 05:27 PM
morthose
Jun 4, 2007 06:40 PM
RaptorRidn9000
Jul 23, 2006 07:55 AM
