front sprocket
Old 08-03-2008, 12:34 AM
bigmo4126's Avatar
Default front sprocket
i need to put a 15 tooth sprocket on my ds650, can sombody explain to me how to change the front sprocket. and how do i reach the needle on the tm45 carb.
Old 08-03-2008, 12:47 AM
cynick's Avatar
Don't know about the carb. But the front sprocket is easy, first loosen the rear carrier where the rear sprocket is. Then take off front sprocket cover and remove nut, I think it is an 1-1/8". Pull off sprocket and install new one. Then repeat process in reverse.
Old 08-05-2008, 10:20 AM
KaylasDaddy's Avatar
Has been riding one thing or another since I was 11 years old.(31 years).
you may want to order a new lock ring( the flat metal "washer" that gets bent over the flat of the nut to lock it in place. some times the tab will break off from repeate bending. as for the carb:
1) remove the topcap (has 3 screws in it)
2)roll the throttle open all the way.
3)look into the hole (all the internal stuff will roll up when you open the throttle) in the bottom you will find an allen head screw.
4) LOOSEN ONLY. the tab that holds the needle in will "swing" away.
5)with a pair of tweezers or needle nose pliers you can grab the needle & pull it out. be carefull though, some times there are spacers under the clip that may or may not come out with the needle.
You will have to hold the throttle open the whole time you are getting the needle out.
It goes back together the oposite way. don't over tighten the allen screw in the bottom. a little torque goes a long way in here.
Old 08-05-2008, 12:40 PM
bigmo4126's Avatar
thank you, openning that throtle made a big differance thanks, oh and your bike looks really cool i like that. also i have one more question you could help me with. im at 3000 ft elevation, and the carb has 150 main, 40 pilat, 97 needle. what should i us for the best power and performance, also what notch should i move the needle to.
Old 08-08-2008, 10:14 AM
don't know about the the jetting for 3000 ft. i normaly don't change the jetting from my standard dune setting until i get to about 6000 ft elivation. that change was 3 jet sizes down on the main & i dropped the needle down 1 notch( raised the clip1). here is a quick rule i used. if you jump on the trottle & it is "boggy" you are a bit rich so use a smaller jet. if it sputters in the mid range( just cruzing) then the needle needs to move( one way or the other ) you will need to play with it to find the sweet spot. this is the way i do mine, it may be wrong to some but it works for me. i have never had much luck with reading the plug method. (black if rich, white or light tan if lean) good luck.
d.
Bratman2
08-06-2022 01:42 AM
STLyamwar
07-25-2020 04:44 AM
carolinabomb
07-26-2015 08:40 AM
95wolv
07-17-2015 08:13 PM
joeyupton
07-14-2015 11:51 AM
Quick Reply: front sprocket
