hot pami 760
Old Jan 6, 2003 | 09:41 PM
DSjockey's Avatar
Default hot pami 760
Was the radiator badly iced by the end of the race?
Old Jan 6, 2003 | 09:51 PM
JEFFROE's Avatar
no they cleaned off the track and i was running alone.
Old Jan 6, 2003 | 09:56 PM
JEFFROE's Avatar
i guess the biggest difference with TT racing compaired to drag racing up a hill is that it never gets a rest or alot of extra air, running hard thru corners then wide open around the back side of the oval. well i'll just thow some cooling tricks at it and hope for the best.[img]i/expressions/face-icon-small-disgusted.gif[/img]
Old Jan 6, 2003 | 10:25 PM
dsmike's Avatar
another thing is if your timing is slow it will heat up.
i have never seen a DS over heat before.
Old Jan 7, 2003 | 12:20 AM
  #15
jeffnrivercity's Avatar
JEFFROE,
When my 703 was losing the head gasket,I think I was in denial....hehehe
I didn't want to believe it...untill it blew water all over the place...
I have a mikuni low pressure tester and special cap to test the radiator,just never tested it before it went,or after..just new what I had to do
Jeff
Even 5 days after it blew,when I took the radiator cap off in the garage..alot of air escaped ..still was alot pressure inside
Old Jan 7, 2003 | 12:37 AM
  #16
14mins's Avatar
Jeffroe- what did robertson say?? How many $$ did robertson charge for a pammi 760??
Old Jan 7, 2003 | 11:21 AM
  #17
JEFFROE's Avatar
ds jockey what type of temp guage do you run?
Old Jan 7, 2003 | 03:18 PM
  #18
DSjockey's Avatar
I run a ESR in the upper hose, you have to lean out and look down but I haven't found it to be a problem although I will eventualy put something in the dash, I'll post a couple of links later for the dash units
Dual guages but they are expensive
Daytona some interesting stuff there
Old Jan 11, 2003 | 12:21 PM
  #19
ScoobyDFW's Avatar
the oil feed from the oil tank has a fine mesh filter than gets clogged with junk, reducing oil flow.
Old Jan 13, 2003 | 11:46 AM
  #20
JEFFROE's Avatar
ok i put on the shrouds the heat seeker and temp guage, ran sunday 150 temp after 3 laps right leg soaked with ani-freeze!! now it's time to do what i should have done last week and replace head gasket,sh*t[img]i/expressions/face-icon-small-disgusted.gif[/img]
fastone21
Apr 1, 2003 10:31 AM
northjeepster
Oct 31, 2002 02:46 AM
14mins
Oct 23, 2002 12:00 AM
Crashfirepm53
Nov 1, 2001 07:52 PM
ScoobyDFW
Apr 4, 2000 06:04 PM
