Best slip-on for the money?
Angry- you decide when you place the order if you want a spark arrester or not. The top-end is there in the pipe. You may need to use a drill and open it up a little. After going to the track and seeing a few run it does not look like it has lost and top-end. I believe that brandon was as fast with just the mbrp slip-on as he was with the full ron wood. he was also a lot quieter. If you think it needs more top- end you can easily fix that.
Folks, that's what I would call, "an unbiased review"!!! Well said there, AngryBB...but I thought you meant it when you said, "she's a runner..." you don't have to lie to make friends[img]i/expressions/face-icon-small-confused.gif[/img]
BTW...whad ya do with that easy going guy I met earlier today? j/k...LOL[img]i/expressions/face-icon-small-wink.gif[/img]
HEy JIM I guess that's why the call ANGRY BAJA BOY!!![img]i/expressions/face-icon-small-happy.gif[/img][img]i/expressions/face-icon-small-wink.gif[/img] It was really nice hanging with you guy's today, just wished wasn't such a wash the last part of the day. It was a pleasure to finally meet you and we will be talking later this week. Thanks again for all of you help.
#15
I have been running A HMF slip on for almost a year now. It did break at the frame mount however I had it welded and have not had another problem since. If I were to install a new HMF I would modify the mounting holes to align properly to avoid the breaking in the first place. HMF is still a quality product that out performs most others.
#16
I saw Angy Baja Boy's HMF break in the exact same place this past weekend. (When I installed the MBRP on mine I had to redrill the collector bracket and also I put a rubber grommet between the frame and the tab...no problems.) I gave ABB my Pro Circuit to use until he could get something done with his HMF and we were amazed at the similarities between the two...the Pro Circuit did not have the mounting bracket at mid section and also the collector swept a little low and touched the frame on his Baja...didn't get a chance to run it due to probs with his CDI wiring[img]i/expressions/face-icon-small-sad.gif[/img]
#17
#20
How are you guys breaking your HMF pipes? I've had mine for a year with absolutely no problems at all. I don't do much jumping, but it seems the quad's frame would have to flex quite a bit to break the pipe. Personally, I'm happy with my HMF, and would reccommend it to anybody.
Quadzilla Heritage
09-25-2015 01:39 PM
Elkaholic
09-06-2015 02:44 PM
