Vbike 250 v4s
Old May 2, 2008 | 05:12 PM
  #241
Coloradotrailrider's Avatar
Default Vbike 250 v4s
Another thing worth taking a look at is the tail light connector. Originally I had a small wiring issue, my headlights didn't work I called Tim at Vbike and he had me pull that tailight connectior apart to check for bent pins. Sure enough I pulled that apart and there were a couple that were bent.
Tim told me the majority of the light issues on th V4S originate in that rear connector.
Old May 2, 2008 | 07:15 PM
  #242
lilc9928's Avatar
haha, oh yea i forgot about that. i looked at it a few months ago and one of the pins was bent all the way backwards and i was suppose to fix it a while ago but i forgot all about that.
thanx
Old May 2, 2008 | 07:18 PM
  #243
lilc9928's Avatar
oh yea im thinking about putting rear wheels spacers in. total of 5 inches, 2.5 inches on each side of the rear wheels. would that make it more stable?
Old May 2, 2008 | 07:26 PM
  #244
split196's Avatar
if you have a link to the site that has spacers can you post it here?
no video this weekend guys but next weekend is a go....throwing down with rain here at the moment and cant be bothered to clean my bike after so next weekend itis....gonna take my camera and try that jump again with the camera rolling
Old May 2, 2008 | 07:31 PM
  #245
lilc9928's Avatar
http://cgi.ebay.com/ebaymotors...rdZ1QQsspagenameZWDVW
its either 5in. or 3in.
im thinking about the 5inches though, u think it'll be to wide?
Old May 2, 2008 | 09:18 PM
  #246
split196's Avatar
i think the 3" ones will bring the front into line with the back...this is a problem for loading for me as when the bike is the standard spacing...(i use ramps into the back of my S10,there is 2" to spare on the loading length and then there is about 10" to play about with in the width on the bed)...the front wheels are about 1.5" wider apart than the back so when loading i have to have the front wheels right on the outside edge of the ramp so the back wheels catch the inside of the ramp and these ramps are 12" wide. but then the 5" set will make for safer handling but i jump about and give mine a hard time so i'm not sure about to much length on a spacer as i dont wanna see if they shear off as i land a 25mph jump [img]i/expressions/face-icon-small-blush.gif[/img]
Old May 2, 2008 | 11:20 PM
  #247
lilc9928's Avatar
yea i'll probly go with the 3in. spacers instead. if i get the 5in. i dont want to ramp and it messing up when i land.
i had a problem with my right front wheel coouple days ago, theres screws on the disc rotor and one of them came loose so it got stuck on some think ( i think it hit the brake caliper?) and locked up on me when i was drivin like 4mph lol but nothin really happened because i was in gravel.
Old May 2, 2008 | 11:27 PM
  #248
split196's Avatar
just look over the bike each time b4 you ride and dont forget to check the rear and front end after a few jump each time....i do and it doesnt hurt to....well i would rather do that instead of hurting my nutts as i crash to the ground after a breakage
Old May 2, 2008 | 11:35 PM
  #249
ghcoe's Avatar
Just dont do anything like this.
http://youtube.com/watch?v=l16PErQsI_s&feature=related
Old May 2, 2008 | 11:38 PM
  #250
I think those spacers that you gave a link to would be fine if you don't plan on jumping like split. For jumping and real hard riding I would go with the solid spacers.
If I were to personally put spacers on the rear of mine I think I would go with the 3". I know that the wider front end is for cornering stability but I'm not sure how it would handle if the rear was wider than the front.
