Redcat VX200 carb upgrade
Old May 26, 2009 | 10:41 AM
4fords's Avatar
Default Redcat VX200 carb upgrade
Can anyone recommend a a carb I could upgrade to on my VX 200?
Thanks.
Old May 26, 2009 | 12:16 PM
mywifesquad's Avatar
KTM Patrol
Former Chinese POW!
Welcome to the forum 4fords1!
What size carb is on it now? Are you running the stock jets?
Old May 26, 2009 | 12:35 PM
4fords's Avatar
I'm on my second stock carb. Changed to this carb last year because the bike would just cough and sputter under load. Drained the carb for winter, started it up this spring and same issue as last year. Took it apart yesterday and saw what appeared to be fine sand in the bowl. Sprayed the whole inside down with carb cleaner, seemed to help a little but still will not run right under load. I don't want to spend another $50 on a carb that will only last a year. The current carb has only about 1.5 hr of run time on it.
Old May 26, 2009 | 12:41 PM
KTM Patrol
Former Chinese POW!
The stock jets are most likely the problem..They are too small so the quad will pass EPA and or CARB regulations... makes them all run poorly below about 4K in elevation.
do you run a fuel filter?
Old May 26, 2009 | 12:58 PM
4fords's Avatar
Yes, the fuel filter is in-line on the bike.
Old May 26, 2009 | 02:31 PM
KTM Patrol
Former Chinese POW!
Weird that sand would get past the filter....I would think with bigger jets it would run a whole bunch better...If you know someone who is a machinist they should be able to drill out the stock jets and make them work better..
Old May 27, 2009 | 02:20 PM
4fords's Avatar
Anyone know if there is a Mikuni that will fit on this bike?
Old May 27, 2009 | 03:32 PM
KTM Patrol
Former Chinese POW!
I would guess you could get a Mikuni to work but there is a huge possibility it will need to be jetted for your quad too.
Is there a name on the carb you have?
Jmuddin284
Jan 19, 2026 07:16 AM
Ean
Dec 19, 2022 08:48 AM
GregM
Mar 6, 2018 06:53 AM
Aitch
Jul 21, 2015 09:40 PM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
