Lifan 250 lf250st-2 wiring question
So I've done a brief search to see if anyone has asked this already but couldn't find anything. I just bought a used 2006 Lifan 250 quad with known issues. First known issue is the cdi is bad so I haveonce in order. Second issue was cut wires. Can't seem to trace where they were cut from though. Then I found a connector without anything on it. Wire diagram shows that the only connector with green, black, black/white and red is four the ignition switch. My questions are is this connection for something else since my ignition switch is connected at the front of the quad, the switch works, cluster works and also will crank with the starter switch?
Pics for reference. Also where does this yellow/white, green and black connect to?
