28 x 12.5 High lifter outlaws require lift???
Old Jul 19, 2010 | 11:52 AM
beergut's Avatar
ʇsıʇɹɐ ɹǝʌolloɹ
Default 28 x 12.5 High lifter outlaws require lift???
Hey guys- anyone running with the 28" High Lifter Outlaws on an 08 outty 650 or 800?
Did you need to lift your atv?
I'm about to pick up a set but I'm not looking to screw with the susp by lifting it. Right now I have the 26" factory tires on- and looks like plenty of room for 28"
Old Jul 19, 2010 | 07:16 PM
beergut's Avatar
ʇsıʇɹɐ ɹǝʌolloɹ
well- never mind. I just mounted them - plenty of room!
Attached Thumbnails 28 x 12.5 High lifter outlaws require lift???-outlaws-4-.jpg
Old Aug 1, 2010 | 09:43 PM
hallj86's Avatar
May i pray for your axels
Old Aug 2, 2010 | 06:21 AM
beergut's Avatar
ʇsıʇɹɐ ɹǝʌolloɹ
Why? the can-am comes stock with one of the strongest axels on any atv (25% thick then the asian axels) and the 28" highlifters are actually only about 1" taller then the stock 26" carlisle skins... it's actually not big deal and they fit quite nicely under the fenders-
Attached Thumbnails 28 x 12.5 High lifter outlaws require lift???-can-am-outlaws-3-.jpg   28 x 12.5 High lifter outlaws require lift???-can-am-outlaws.jpg
Old Aug 2, 2010 | 07:51 AM
hallj86's Avatar
Its the lugs grabbing hard and I dont know of many people that dont go through stock axels with outlaws.
Old Aug 2, 2010 | 10:42 AM
beergut's Avatar
ʇsıʇɹɐ ɹǝʌolloɹ
People have more problems with their axles (cv's) when modding clutches and adding lift kits- also, most axle failures I've seen happen because the rider is not experienced and has no clue how to properly throttle through an obsticle. 28" outlaws for big bore outty won't be a problem- the polaris & can-am axles are the beefiest out there- and I'm a pretty experienced rider.
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
r1pilot83
Sep 27, 2015 07:38 PM
BYC
Sep 25, 2015 02:10 PM
cboler9
Sep 24, 2015 08:35 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
