What is the ULTIMATE dirt drag tire for High HP quads?
So, what is it? for loose dirt, on a High-hp Yamaha Raptor? Does ITP make a 22in Holeshot XC, or XCT that is 2-ply? I want a light tire, and on .125 rims. Pro wedges are too expensive, Maxxis 4-snows can't be found anywhere, I like Honda radials, but I want a 22in tire. If anyone has tires/rims, I have some I'd be willing to trade.....
2- 20x10x9 Kenda Dominators
2- 21x7x10 Holeshots
2- 20x10x9 Dunlop Radials
2- 21x7x10 Dunlop Radials
2- 21x7x10 Ohtsu Radials
2- 10in Douglas .190 rims for DS650 with outer reinforcing rings.
2- stock DS650 .190 rims
4- all stock Raptor rims.
I would like some 19x7x10 Holeshot Mx's to lower my front for drags.
a buddy of mine got a set of realators on his raptor and in a dirtdrag it just hooks up and rips beat this one dude in a drap with his rappy and holeshots... and he had a pipe jet kit air filter and a 727 kit and my budds raptor just had a T4 pipe and a kn filter and jet kit
You want to run a MX tire like a Holeshot for dirt drags? But you don't want to spend the money for a good tire like a Pro Wedge? If you want the ultimate tire for the sand drags you need to spend some $ for them. Run the Skat Trak Haulers. They are the best sand drag tire.
Hey yuck mouth, since your so fu-king smart you should not have to come in here and ask for help. A smart a$$ like your self knows everything. Yet you come in here and cry for help. Boo hoo........ As you should know a Hauler tire is NOT just used in sand. It is used on all but the hardest packed dirt surfaces. But you know everything. So why don't you take your tires that you have now and shove them directly up your a$$ you little puke...................
I don't come in here boo-hooing kid, I just as k for opinions, that's what this board is for. Yes, I know haulers are used for everything, but you said use them for sand drags. I don't do sand drags. You came in here bitcin, "Why are you using a mx tire for drags, get a pro-wedge" wah-wah-wah. Shut up, if your not going to be any help, then go away.
First of all I am not a kid, I am probably older than you.
I came in here to help you, to tell you what I have used in the past for different tires. And then you sh-t on me for trying to help you? What the fu-k? That takes a lot of nerve. You did not have to post a negative comment about what I said. You should have just kept your mouth shut and not said any thing.
But you show every one on the board how imature you are, and come in here running your gums.
When you grow up and you can act like an adult, then maybe we can talk on a intellagant level.
Yes I said use Haulers for drags but isn't that what you asked? What is the ultimate drag tire? Who is the dumb a$$ now?
Boo hoo, pro wedges tires are to expensive. Well if you can't afford to play then you have no right playing on the track
drag295 is rite i have paddels and drag in the dirt every weekend(loose dirt)
dont get paddels if you ganna go on hard pack thow
but on the other hand i dont know if a raptor is powerfull enough to turn paddels Jk j/k j/k j/k (just kidden)
