yamaha warrior 350 wont start
Old 05-10-2014, 01:52 PM
Brien6748's Avatar
I have a 2003 Yamaha warrior that won't start I put a new carb new starter new plug new stator it started an ran for a minute but won't start now need help!!!
Old 05-19-2014, 01:02 PM
Bayou300ex's Avatar
If I where you I would check to see if the choke closes all the way.
Old 12-17-2014, 01:36 AM
Nixonsbudz's Avatar
Bought a 95 yahama warrior 350 running but needed a carb rebuild. I did that and started it right up and let it run for 20 min then it died and would not start back up. Replaced the stator, pick up coil, ignition coil. Has a blue spark and is getting fuel. Won't push start either. It just cranks over and over but still nothing. Any help would be very appreciated.
thanks
Old 12-17-2014, 08:04 AM
Brien6748's Avatar
Default warrior 350
thanks
my sons 04 warrior did the same thing it was the neutral safety switch I took that out and the quad runs great now if that's not the problem check the wiring I had to rewire my sons quad
  #15
Old 12-17-2014, 08:39 AM
Nixonsbudz's Avatar
Did your sons quad neutral light come on when it wouldn't start? Mine light is working when in neutral. And would it start if you tried to push start it
  #16
Old 12-17-2014, 08:57 AM
Brien6748's Avatar
it never had a light on it try to pull the clutch in then start it. And my sons quad wouldn't push start it would try but it wouldn't start. Have u checked the fuse
  #17
Old 12-17-2014, 09:04 AM
Nixonsbudz's Avatar
I've tried pulling the clutch in and nothing. Havnt checked the fuse "not sure where it's even located" but the fuse wouldn't prevent the push start. At least for my honda it didn't when it went out.
njrider64
07-04-2017 01:40 AM
mikey426
06-17-2015 03:53 PM
dano00
10-07-2000 08:13 PM
PuhiStrain
09-09-2000 01:36 PM
dunc_n
08-26-1999 09:32 PM
Quick Reply: yamaha warrior 350 wont start
