2003 Gator manual
Old 10-10-2009, 07:22 PM
Sisco1957's Avatar
Default 2003 Gator manual
Anyone know wherre I can find a pdf manual. I need to know about the primary clutch. Thanks.
Old 10-13-2009, 11:39 AM
tramp's Avatar
What do you need to know about the primary?
Check on J.D. web site.
I have a manual for a TM model, may help with question.
Old 11-01-2009, 08:58 PM
Sisco1957's Avatar
A friend was asking how to inspect and remove the primary clutch.
Old 11-18-2009, 02:29 PM
tramp's Avatar
The clutch is pressed onto the tapered end of the crank shaft. A special clutch puller is needed to remove the clutch. You can get one through a J.D. dealer. Well worth owning .
You can inspect and clean the clutch by removing the screws in the cover.
Best way to clean is just use an air gun and blow it out good.
Check play in the weights and bushing. DO NOT grease or spray any type of oil in or on the clutch. You can if you want use brake clean and then blow out good with air.
Old 11-18-2009, 08:49 PM
Sisco1957's Avatar
Thanks for the info.
Old 01-28-2010, 01:39 AM
will56's Avatar
Impalaman
1) Engine problems..
12
11-08-2015 07:17 AM
Clint Russell
09-25-2015 03:20 PM
95scramblerruben1033
09-23-2015 06:29 PM
Ridgerunner665
09-15-2015 01:20 AM
Hw00d
09-10-2015 08:53 AM
Quick Reply: 2003 Gator manual
