Reverse Switch???
Old Dec 20, 2005 | 12:07 AM
maddmudder13's Avatar
Default Reverse Switch???
thing is about locking that button up is if, if your like me i ride agressive and when i get exciting and need to stop on a dime i lock up every brake i have so i could very esily break the reverse cable. but i found a great alternative, though a little pricey,
http://cgi.ebay.com/ebaymotors/Rotat...98110359QQrdZ1
im pretty sure this would work and would be very very slick to use. just push in that button and shift down and your in
Old Dec 20, 2005 | 12:28 PM
theref's Avatar
I combined 2 of the ideas that I got from here and it worked! I used a cable tie and put it around the reverse cable itself once it was pulled out and engaged. Then when you let go the brake lever goes back to it's normal position and the button pops back up but the bottom part with the reverse cable stays open! Now all I have to do is shift from nuetral to reverse without having to touch anything else. Also this way if you ride agressive like maddmudder13, then you do not have to worry about breaking the cable as it now does not move with the lever anymore! This will be great for plowing![img]i/expressions/face-icon-small-wink.gif[/img]
Old Dec 20, 2005 | 01:52 PM
thats great idea, ill havto do that for when i plow, that would be alot lot easier, just gotta becarful of when you shift into neutral, could accedently pop into reverse
Old Dec 20, 2005 | 02:31 PM
BamaHonda's Avatar
Wow!! A lot of great ideas on this subject.I figured the response I would get is that I was just lazy.I have'nt had time to mess with mine yet because i've been hunting like a fool here lately.Surprised i'm still married.Next break I get i'm going to start on mine.Whatever I come up with i'll post it.
Thanks,
JE
Njrider1230
Jul 29, 2023 05:16 AM
Reactant
Mar 30, 2022 02:08 AM
mbkirk
Aug 14, 2015 08:20 PM
mbkirk
Technical and How-To Articles
Aug 14, 2015 08:12 PM
ScopeZ_
Jul 28, 2015 01:44 AM
