03 rancher es no reverse
Old Apr 2, 2007 | 01:30 PM
phantomsite's Avatar
Default 03 rancher es no reverse
Hello all i have a 2003 rancher es, My buddy's and i stopped for a quick rest while riding and when we went to go i not go in reverse. unless i manually shift it with the handle by the trans. The strange thing is that i can down shift just not electronically shift into reverse. Anyone with some ideas as to the cause i would greatly appreciatted it.
Old Apr 2, 2007 | 08:10 PM
SpinalTap's Avatar
Well my 2007 Rancher is at the Honda shop for not shifting into reverse or gearing down while any brake is appied.
Try holding the button in on the brake light switch on your handlebar while you are trying to go into reverse.
Right now The Honda shop is having no luck trying to fix mine. Good Luck!!!!
P.S. Let me know if this is your problem
Old Apr 2, 2007 | 08:37 PM
03250bayou's Avatar
my dads '02 had the same problem..trace all the wires and see if there's a loose connector, thats what he did..tighted it up and it worked again
Old Apr 2, 2007 | 10:00 PM
mykool61679's Avatar
the reverse wire runs along the bottom of the quad if this is the only problem, then chances are thats the problem.
Old Apr 2, 2007 | 10:25 PM
Lobster's Avatar
Wire is likely pulled off on the bottom back of engine. A little black wire with a 90 degree boot. You may have to lightly crimp it. Its almost dead center at the back of motor up about an 1" or 2"
Old Apr 3, 2007 | 10:08 PM
Hey everyone that little wire on the back of the engine was it thanks alot!!!!!
vandammages@gmail.com
Aug 20, 2020 11:50 AM
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
Johnny Mac
Aug 15, 2019 03:13 PM
r1pilot83
Sep 27, 2015 07:38 PM
Clint Russell
Sep 25, 2015 03:20 PM
