Honda display code
Old Jan 2, 2008 | 04:39 PM
doublejay's Avatar
Default Honda display code
hello everyone,,i have a 2006 rubicon. Had it since feb last year and have about 960 miles and 150 hrs on it, The other day,,i took it out the shed and was idling and when i put it in gear,,the display selector it started flashing,,once,,pause than five times,,,,i shut if off and started it back and went off to ride..rode about 2 hrs and it did it again only ofter putting it in reverse,,like it had a terrible miss fire in it,,. I made it back home and check the sensor down by the left foot thats all i done so far.. Yesterday,,i went riding rode all day long ,,never messed up,,i mean in some treachous places done,,perfect..until time to go home and started flashing again,,,i ride in water often ,,but nothing to sink my 4 wheeler,,usually bout fender deep...any suggestions what it could be !!!
Old Jan 4, 2008 | 10:00 AM
JeffinTD's Avatar
Here's a thread about pulling codes...
http://forums.atvconnection.co...atid/8/threadid/532744
I believe 5 is angle sensor/motor lock.
Old Jan 4, 2008 | 11:48 AM
doublejay's Avatar
thanks man,,i have another ?..how long will i be able to ride like this,,like i said it doesnt do it often and if i start my atv in gear and take off it shifts fine no problem until i come to a complete stop,,than it might do it and it might not,
Old Jan 4, 2008 | 01:15 PM
JeffinTD's Avatar
Assuming it's in limp mode where the transmission locks in a mid range, I would think it might be hard on the clutch... I'd get to the bottom of the problem and get it corrected before I'd run it...
One of our real experts will hopefully chime in.
Old Jan 4, 2008 | 08:13 PM
doublejay's Avatar
when i start it up in limp mode in gear take off within a sec or two,,it shifts fine threw all the gears like nothing is wrong,,even in esp mode i can go threw all the gears,,when i stop for more than 3 secs,,it sometimes blink,,like 2day,i started it up and it ran perfect,,no limp mode or nothing,,just like a Honda should,,im gonna get it fixed but i dont want to pay a diagonistic fee ($80)for a problem they cant find until it happens,,if you know what i mean
Old Jan 4, 2008 | 09:03 PM
JeffinTD's Avatar
Being intermittent like that, I'd be inclined to pull the negative battery cable and take every connector I could find apart to clean them up, blow them out, and hit them with some diaelectric grease...
Old Jan 4, 2008 | 09:17 PM
doublejay's Avatar
i surely will,,probably get to it 2morrow the weather here suppose to be nice,,i cleaned a couple connectors today,,had a little sand in them,,i thank you for all the help,,and i'll let u no something 2morrow,,after i ride 4 awhile
Old Jan 5, 2008 | 02:56 PM
doublejay's Avatar
well time has come,,i thought i was going riding today,,but as soon as i pulled my Rubicon outta the shed it went in i guess what is called "limp mode",,i tried resetting the ecm and cleaning the terminals and same thing,,so i guess im gonna have to take it to the shop Monday and let the find the problem,,it still has a flashing "5" code so maybe i have a bad wire or something,,maybe wont be in shop long,,i'll everyone posted on the outcome and maybe i'll be a help to someone else...thanks for everyone help,,
Old Jan 5, 2008 | 03:27 PM
JeffinTD's Avatar
My guess would be angle sensor then...
Old Jan 5, 2008 | 08:39 PM
doublejay's Avatar
I believe i have it fixed,,i did a code reset earlier but i forgot to open the throttle while the sensor was resetting,,i did it over again just as the manual said and the code not flashing anymore,,i been out riding and so far so good,,so lets pray that was all wrong with it!!!!
Bonzhonda300ex
Sep 17, 2015 10:44 AM
Steeldon
Sep 8, 2015 10:51 AM
rawbdiggity
Sep 7, 2015 12:05 PM
DGNAZ
Sep 5, 2015 09:14 PM
jldominic
Honda Side by Sides
Aug 8, 2015 06:54 PM
