honda rancher 350
honda rancher 350
I have ridden the bike for over an hour then let it just set and run in the shop and the fan has never came on.
I have checked the fuse and it is fine, so am I not getting it hot enough or could the fan be bad? The air temp was about 50 if that makes a differance, but in my shop I had the heat on about 80 and idled for 30 minutes but still no fan.
honda rancher 350
it will take a few hours for the oil to "burn" and change to black, but if it gets black within 4-5hours of change there is something wrong. the header glowing means you are running lean...not overheating as much. you need to richen you pilot jet...if it constantly gets red-hot you can melt the piston [img]i/expressions/face-icon-small-sad.gif[/img]
Elkaholic
09-06-2015 02:44 PM
