just got carbs fixed now bigger problem
Old Apr 11, 2009 | 12:48 PM
e123pedro's Avatar
Default just got carbs fixed now bigger problem
i just fixed the carbs on my 03 honda rancher ES 2x4 and was riding around the house when all the sudden it stopped running and i was surrounded in a cloud of blue smoke. I let it sit for awhile and started it back up, it runs, but leaks blue smoke out the exaust big time. My question is what is wrong? how difficult is it to fix? also a idea of how much it cost would be great.
thanx
Old Apr 11, 2009 | 12:59 PM
rtmillerx's Avatar
Smile Blue smoke
Blue smoke definately burning oil, check your compression to see if your rings are worn
If compression is good, then sounds like you have a valve issue, check your valve adjustment/clearnces and if thats good i would assume you have a bad or burned valve, leaking valve seals or worn valve guides.
Just by chance- did you recently fill your oil?
If so it might be overfilled-make sure when you check the level not to screw the dipstick back in, just dunk it down as far as it will go and check the dipstick. I have had a few smoke like crazy when they have been overfilled.
Hopeully its an easy fix and you will be back on the trail soon
Old Apr 11, 2009 | 03:57 PM
HondaMechanic's Avatar
Did it seize or make any noise when or just before it quit running ..?..
Old Apr 11, 2009 | 06:25 PM
e123pedro's Avatar
no, it gave me no warning it was blowing up, until it just quit
neilbedwell
Nov 10, 2018 11:02 AM
sticky123
1) Engine problems..
Jun 14, 2015 07:36 AM
generalpops
Jun 5, 2015 08:23 PM
generalpops
Jun 3, 2015 08:25 PM
