trx450 problem at high engine rpm
Old Apr 25, 2009 | 01:13 PM
07TRX450Ryder's Avatar
Default trx450 problem at high engine rpm
Hi, i have a probelm with my 07trx450er that i cant figure out. i went riding one day last week and the quad was performing very well, never had any problems with it. i came home washed it pretty good and parked it in the garage for the week. i went to go ride it again the next weekend and it starts and idles fine and sounds good at idle. when i rev up the engine it bogs down and somtimes will die out. i checked the fuel flow from the tank was good, replaced the plug with original equipment from honda and the air filter, still no luck. i took the carb off and everything looked very clean in it and it seemed to be working properly but i never really took a 4 stroke carb apart. does anyone have any ideas or suggestions for me??? Thanks
Old Apr 25, 2009 | 01:48 PM
Turfguy's Avatar
make sure the vent hose from the fuel tank is not pinched somewhere.
Old Apr 25, 2009 | 02:08 PM
yes it is good
Old Apr 25, 2009 | 04:16 PM
murox's Avatar
did you accidentally spray water in the exhaust? My friend did that to his blaster and it did the same as yours. My little brother got a bit in my banshee's pipe once and I let it idle and it burned it out. Luckily the banshee has the weirdest stock pipes I've ever seen and that probably actually saved me a rebuild. Just let your machine idle for 10 minutes and see if anything changes.
Old Apr 25, 2009 | 06:20 PM
coryatver's Avatar
Originally Posted by 07TRX450Ryder
when i rev up the engine it bogs down and somtimes will die out. Thanks
It will die out like that when it is not warmed up yet. If it does it when it is warmed up They have a rev limiter if you are reving it up it will bog down and die out. Since you already changed the plug and air filter only other thing i could think of is maybe you got water in your gas but I am really thinking you are just hitting the rev limiter. Does it do it when you are hard on the gas riding it normally as in you shift it at the correct times? If so i would have to say it is definitly the rev limiter
Old Apr 26, 2009 | 09:32 AM
its definitly not rev limiter, it doesnt rev high enough to get to rev limiter. i do think its possible i got water in the pipe though. ive started it but havent let it run for any period of time im gonna try that next.
Old Apr 26, 2009 | 08:27 PM
i tryed letting it run for a while and it didnt change anything. i think im gonna try to tak the pipe off and see if there is any water in it. IM GOING CRAZY
Old Apr 27, 2009 | 09:58 AM
trex450's Avatar
check again man its definitely the rev limiter if u are letting it warm up :}
Old Apr 27, 2009 | 10:19 AM
i cant get it past quarter throttle so i know its not the rev limiter. any other ideas?
EZRyde
EZ Ryde Exhaust
Jul 30, 2015 12:46 PM
scaldwellk
Jun 19, 2015 05:08 PM
Big600twin
Jun 10, 2015 03:01 PM
hugemoth
Jun 4, 2015 02:56 AM
kevbowe
Jun 1, 2015 01:17 AM
