2006 Honda Rancher Automatic Shift Problems
Old Apr 27, 2009 | 03:03 PM
Bongomon's Avatar
Default 2006 Honda Rancher Automatic Shift Problems
I have a question about a 2006 Honda Rancher 4x4. The ATV has both Automatic and ES capability. The ATV performs fine in the ESP mode, but in Automatic mode it revs the engine but does not move along. If you let off the throttle and then puch the throttle again the bike will move along just fine. It just acts up when you try to start out a slow pace. It does not matter if you are going uphill, down hill, or on level ground.
We have checked the battery connections and the oil. The bike has about 600 miles on it and we have had it since it was new. We have also checked for error codes and none are retieved. Does anyone have any suggestions?
Old Apr 27, 2009 | 05:37 PM
HondaMechanic's Avatar
Does it seem like it's trying to take off in to high of a gear ..?
Old Apr 27, 2009 | 08:48 PM
Bongomon's Avatar
Yes, when it is having a problem it does seem like it is starting in high gear. I had the bike out again tonight and based on some other things that I have read I was trying a few things. If I run the bike up to about 20 mph and then slowly bring it back down the transmission acts fine. But if I run the bike up to about 20 and abruptly brake and stop the bike, then it acts up again. To correct the problem, I can then run the bike back up to 20 or so and slow down gradually and the bike performs correctly until I stop it quickly again. To me it acts like if it does not have time to shift down, then it gets confused what gear it is in and tries to start out again in a high gear. When it starts out in a high gear, I can also shift to nuetral cut the bike off and then start it up again and it acts fine. Little bit too much information, huh? I have a service manual, but I don't quite know where to start. I appreciate any help you can give me.
Old Apr 27, 2009 | 10:13 PM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
We have seen a fair number of posts on problems with this model. Perhaps there is some universal problem with it that can be discerned from all this. Honda discontinued it after only a couple years of production....perhaps for some good reason???
A search might help, but not sure what search terms to use? Even you didn't know how to properly identify your model....but I would start by searching "Rancher 400AT" for starters.
http://forums.atvconnection.com/sear...searchid=62864
Old Apr 28, 2009 | 04:54 AM
I would first initialize the ECM as discribed on page 24-9 to 24-11 ... Honda had an updated ECM for the 2004 model but the ECM wasn't the main problem , the problem was the centrifugal clutch ..
Old Jan 14, 2013 | 11:10 AM
KMKjr's Avatar
Was the problem ever found?
My brothers is doing the exact same thing.
Old Feb 3, 2013 | 07:57 AM
craneman1's Avatar
i have a 07 rubicon 500 and my error code is flashing 5 i dont know the fix for this and is it what yours is doing
Old Feb 3, 2013 | 08:02 AM
craneman1's Avatar
Default 2007 rubicon error 5
my atv is flashing error 5 and i was told that it was the ecm over the phone can anyone check the book for me to see what error 5 says please
neilbedwell
Nov 10, 2018 11:02 AM
ROWALKER
Jun 15, 2015 05:38 PM
Dpearson03
Utility ATVs
May 29, 2015 04:51 AM
aby11
May 7, 2000 07:58 PM
Rancheres4X4
May 5, 2000 02:09 AM
