Trx300
Old Apr 11, 2012 | 05:24 PM
buda01's Avatar
Question Trx300
I have just overhauled my 1996 Honda Fourtrax 300, Clutch, with NEW DISC.,Clutch Plates and springs When I started it up and put it in gear the Engine Stalls I read a Post about where you can Pull the shift lever UP and hold it there and it would make the Clutch DISC. UN-stick, Well I did that and when you let go of the shift lever the Engine Stalls? right now I'm Lost for any ideas that would shovel this Problem I did check the Centrifugal Clutch Lining and springs,everything check out!!!! All I got to say is "HELP"
Old Apr 12, 2012 | 07:23 AM
budedm's Avatar
Did you soak the plates in oil for a day before you installed them? Try putting it in gear without the engine running. Pull the clutch lever in and rock the bike forward and backward until it rolls freely. Sometimes this will unstick the plates.
Old Apr 12, 2012 | 10:31 AM
buda01's Avatar
budedm
I did soak the clutch plates in Honda engine oil for 24 hrs, "YES" I tryed putting it in gear with the Engine off, and pulling up and holding it there, and the ATV rolls, just like it does with the engine running and the shift lever held in the up position.
Old Apr 12, 2012 | 10:36 AM
budedm's Avatar
Does it stall as if it's an electrical problem? Maybe you forgot to reattach the reverse wire or something?
Old Apr 13, 2012 | 07:49 AM
buda01's Avatar
Smile Trx300
All the wiring is correct,I feel it could be the ONE WAY BEARING in back wards??
Cheers
Buda01
Old Apr 13, 2012 | 08:47 AM
budedm's Avatar
Ahhhh. Good thought. Could be.
Old Apr 13, 2012 | 09:56 AM
buda01's Avatar
Default Trx300
ahhhh. Good thought. Could be.
"thanks"
Old Sep 25, 2012 | 10:30 AM
trx300man's Avatar
What did you find out?
sdgundog
Jun 26, 2006 12:34 AM
ftwflh
Jun 19, 2006 12:06 PM
hiofcer
Aug 7, 2004 08:43 PM
pungohboy
Apr 7, 2004 05:26 PM
Jerms
Oct 15, 2002 06:05 PM
