honda trx 450 foreman es
Old 12-12-2014, 01:31 PM
andrew63's Avatar
Default honda trx 450 foreman es
does anyone know what 7 flashes means on an es with up shift problems
Old 12-12-2014, 03:07 PM
DGNAZ's Avatar
ECU Voltage convert circuit.
It says to key off/on and recheck, and if you still get 7, replace the ECU and retry.
This from the Factory Service Manual through 2002 ( when i bought the manual ), but i would think it applies to the final years as well.
With a little Googling, its pretty easy to find a free FSM download for these.
Old 12-13-2014, 09:34 AM
Not sure if it is relevant, but voltage fault codes sometimes are a result of the voltage regulator. 450s have a habit of refusing to start if the regulator packs in, but it is worth checking the voltage across the battery, with the engine running, is between 12 and 14.5 Volts, any more and it can effect the ES system.
Old 12-13-2014, 12:43 PM
DGNAZ's Avatar
Absolutely relevant.
Electrical problems are bad enough without trying to hit a moving target. Low batteries or poor charging can cause all sorts of strange behavior by themselves.
Old 12-15-2014, 01:21 AM
andrew63's Avatar
thanks for info
have 14.6v over battery and 8 flashes
Old 12-15-2014, 03:19 AM
14.6v is near enough, and won't cause problems. Can't remember what code 8 is, I suspect it is an angle sensor code.
Old 12-15-2014, 10:26 AM
andrew63's Avatar
thanks
Old 12-15-2014, 12:30 PM
DGNAZ's Avatar
Code 8 is angle sensor.
NewGuy2481
10-06-2015 05:54 AM
Johnny Mac
09-27-2015 08:33 PM
stcspiderman
09-13-2015 05:15 PM
XxS0ccerstarxX
09-08-2015 06:54 PM
Jason Campbell
09-07-2015 02:25 PM
Quick Reply: honda trx 450 foreman es
