PEP Ez Clutch Perch....What is it?
Old May 12, 2001 | 09:59 PM
HondaMan85's Avatar
I've just bought a 250R that i'm fixing up, and i've seen numerous posts where people have the PEP Ez Clutch Perch on their Honda 250R's. What exactly is it, and what's so good about it? Where can i get one and how much?
Old May 13, 2001 | 11:34 AM
LT80's Avatar
LT80 Expert
it makes the clutch easyier to pull, it re-locates the hole the cable sits in, altho i have found it nessesary to grind the sharp edge off where the cable hits the perch (it breaks cables fast if not ground off). RTC makes a fine ez clutch also good luck w/your R
Old May 13, 2001 | 10:10 PM
4ooex's Avatar
i just got the RTC perch and lever from kandkatv.com and its a great deal easier than stock, its pricy(54.95) but its well worth it.
00 400ex
Big gun complete,K&N filter and jet kit,Ac mudscreen bumper,Dg baja swingarm skid, custom stanless chassies skid, One industries graphics,nac's light covers, RTC clutch and brake levers,ShockWears all around,and shaved front fenders. on the way: rental bars, yellow plastic,Quad-tech carbon fiber hood, and hopefully a JE high comp piston and cam,bandit front and rear tires.
Old May 14, 2001 | 12:44 AM
poolhustler's Avatar
Nacs racing has the EZ clutch for $34.95. It makes the clutch 33% lighter pull than your stock clutch. Their number is 845-246-3086. Hope this helps. PH
buddieboy
Dec 9, 2016 05:50 PM
tysonbully
Sep 28, 2015 02:30 AM
jbrewster94
Sep 23, 2015 04:16 PM
roy.hawkins3@gmail.com
Sep 11, 2015 02:35 PM
cdstang
Aug 31, 2015 07:52 AM
