No reverse Rancher 350ES 4x4
Old 08-15-2002, 06:10 PM
gverb1219's Avatar
I dont think the problem with mine is the switch, because it shifts up and down fine........except reverse.[img]i/expressions/face-icon-small-confused.gif[/img]
Old 08-15-2002, 06:17 PM
Kenny10's Avatar
Mine would also shift up and down through forward gears fine - but no reverse. Try grounding the wire to the reverse shift switch. If it now shifts OK, then the problem is in the switch - replace it.
2000 Rancher350ES 4X4
Old 08-15-2002, 06:21 PM
Kenny10's Avatar
Sorry - should make it clear that the 'reverse shift switch' is what Honda calls the switch at the bottom rear of the engine that robo181 has talked about. (It's not the switch on the handlebar)
Old 08-15-2002, 06:23 PM
bbertram's Avatar
oh.
  #15
Old 08-15-2002, 06:54 PM
gverb1219's Avatar
You were right Robo181. It was the plug, I was messin with the wrong one. It works fine now. I have added a link to some pictures of the plug for anyone else. Its right where you said, under the middle, bottom of engine.
Thanx Robo
Pictures
  #16
Old 08-15-2002, 07:07 PM
robo181's Avatar
GLAD YOU FOUND THE PROBLEM. I WAS PRETTY SURE THAT WAS THE PROBLEM BECAUSE YOUR SYMPTOMS WERE EXACTLY LIKE MINE. A FRIEND OF MINE IS A HONDA MECHANIC AT FUN MOTORS IN LONGVIEW AND HE TOLD ME ABOUT THE REVERSE SENSOR ON THE BACK OF THE MOTOR. HE SAID THIS PROBLEM DOESN'T OCCUR OFTEN. GOOD ADVICE IS LESS THAN 56.00 PER HOUR. WHAT A GUY. HA
  #17
Old 08-16-2002, 12:12 AM
Elrancho's Avatar
Interesting this thread is here... I lost reverse last year and diagnosed it( you could probably find it by searching). The reverse lockout[dummy] system on the honda can be overridden. If I ever have the case apart I'll likely remove the offending system and ground the reverse shift switch, when that's done the ES should shift stright past nuetral and into reverse no button or sensor/wire issues.
vandammages@gmail.com
08-20-2020 11:50 AM
r1pilot83
Utility ATVs
15
11-25-2019 11:39 PM
Johnny Mac
08-15-2019 03:13 PM
r1pilot83
09-27-2015 07:38 PM
Clint Russell
09-25-2015 03:20 PM
Quick Reply: No reverse Rancher 350ES 4x4
