YES OR NO ANSWERS NEEDED QUICK! DEAL?
Old Nov 18, 2002 | 09:11 PM
YAMABEAN's Avatar
Default YES OR NO ANSWERS NEEDED QUICK! DEAL?
I HAVE A CHANCE TO BUY A EARLY 90'S FOURTRAX 4X4. SOMEONE GOT A LITTLE HAPPY WITH THE CAMO PAINT EVERYWHERE! MAY NEED NEW PLASTIC BUT HAS NEW TIRES. IF THIS THING RUNS OR TURNS OVER AT THE LEAST------------------------> IS IT WORTH $300 I HAVE TO GIVE FOR IT????????????? I THINK IF I HAD TO GET OUT I COULD PART IT OUT ON EBAY.. IT'S A 4X4!
Old Nov 18, 2002 | 09:17 PM
love250x's Avatar
If it runs do it. If the lights work do it. If it has 4 tires do it.
Old Nov 19, 2002 | 12:37 AM
Raptoryfn660r's Avatar
RIP Dear Friend
If it runs its worth that.
Chet
Old Nov 19, 2002 | 01:09 AM
KNOWSALOT's Avatar
The Facility
Well, it can't be anything other than the TRX300FW, so I think that's a pretty good deal for $300.00
Parts are readily available and unless it's been dropped from a hlicopter, you should be able to fix it and still keep the bottom line cost under the value of it.
Nearly all parts from the 1999-2000 TRX300 models fit the older versions and these parts are usually up to 75% cheaper than the older ones simply based on where the parts were manufactured!!
Plastic is no big deal. You could get a new grille, front fenders, rear fenders, kick starter cover, and all the decals for under $300 if you order from a 2000 model. All the plastic will interchange from any other TRX 300.
The fuel tank in a different story. Honda uses a Japanese vendor to produce all of their fuel tanks that are made from steel. They are very pricey. If yours doesn't show any signs of rust, sand and prep your tank for paint and contact Color-Rite Distributing. They deal direct to the consumer and are the ONLY company authorized to produce EXACT color matched paint for any of the Japanese Motorcycle and ATV companies.
Good luck with your new project!!
Patrick
Old Nov 19, 2002 | 01:15 AM
YAMABEAN's Avatar
THANX A MILLION KNOWSALOT! IM A YAMAHA FANATIC BUT NOT TO KNOWLEDGABLE ON THESE HONDAS, YES THEY ARE GOOD AND EASY TO WORK ON ALSO. I APPRECIATE ALL THAT AWESOME INFO.. IT WILL HELP, ACTUALLY IM GONNA PRINT IT. LOL
neilbedwell
Nov 10, 2018 11:02 AM
TegraQuad
1) Engine problems..
13
Nov 26, 2017 01:40 PM
jrooker6
Ask the Editor
11
Apr 21, 2016 07:35 PM
RPK
Jun 8, 2015 01:05 AM
