Clutch Compresion Tool
Old May 28, 2003 | 06:23 PM
Lightman's Avatar
Default Clutch Compresion Tool
Just FYI, EPI sells a clutch compression tool, very similar to the one nyroc provides instructions to make, to install the black spring. It's $79 and the part number from EPI is CCT500. Just FYI for those who aren't able to make the tool themselves....
Old May 30, 2003 | 11:29 PM
AJ650's Avatar
Boy, if you can't make a compression tool, you probably shouldn't be doing your own maintenance. You don't even have to do the nyroc route, 10 minutes in just about any garage should turn up enough junk to fab your own.
Old May 31, 2003 | 12:24 AM
Lurch77's Avatar
If you don't want to or can't make a tool for some reason, call Mike Penland. He sells them for $50. Same one Kawasaki sells for $70.
Old May 31, 2003 | 11:18 AM
PLATEANDFOURSCREWS's Avatar
Sean"Lurch" You have a pm.
Mark
buddieboy
Dec 9, 2016 05:50 PM
tysonbully
Sep 28, 2015 02:30 AM
jbrewster94
Sep 23, 2015 04:16 PM
roy.hawkins3@gmail.com
Sep 11, 2015 02:35 PM
cdstang
Aug 31, 2015 07:52 AM
