V-Force vs. Banshee vs. Raptor - My Results
Old Jun 26, 2003 | 11:04 PM
  #61
nyroc's Avatar
Default V-Force vs. Banshee vs. Raptor - My Results
Bigone, sorry for stopping by at the wrong time. I didn't get home to see your post. I like how those handlebars look. They look just plain awesome.
I weld steel with a MIG. I like to use my brother's inner shield welder for volume welding. If it is crucial, I mig it. I have made a few trailers and other stuff. I made a bead breaker among other things. I weld cracked quad frames. I am thinking about an aluminum setup. I have thin wire for bodywork, but I don't have tools or patience to do body work. Between my bro and I, we have the tools to cut and weld steel bars, tubes, channels and stuff.
Old Jun 27, 2003 | 12:48 AM
  #62
TEDDY700's Avatar
WELL WENT AND RODE IT AGAIN WITH THE YELLOW PRIMARY AND BLACK SECONDARY AND IT IS FAST ON TOP END BUT I CANT LANCH THE DAMN THING. IT ENGAGES TO LATE IF I LANCH IT HARD IT WOULD FLIP, I WAS RACING 02 CANNODALE BUILT TO THE MOON AND COULDNT BEAT IT WITH THIS COMBO CAUSE OF LAUNCH. WENT AND PUT IT BACK TO STOCK AND I COULD TAKE HIM BY A COULPE OF QUAD LENGTHS? WEIRD BUT I JUST GOT BACK INSIDE AND I COULD LAUNCH ALOT HARDER WITH STOCK SETUP......ILL WAIT A COULPE DAYS AND TRY THE GREEN I ORDERED I HERE ITS BETWEEN THE YELLOW AND STOCK ....WILL SEE
Old Jun 27, 2003 | 11:00 AM
  #63
Speedwerx's Avatar
were trying to get one of these quads in the shop right now. i can only hope one of you guys on the forum is local maybe i'll get lucky i think right now our breen spring is going to do the best for piped or stock machine the rate doesn't seem to harsh but i think it will pull alot harder i want to get one in here right now to try some new stuff, today only 6-27-03 10% of all springs to customers who call me and tell me they read this i need to get these springs out there so that every one knows were to go thanx jeremy 651-982-0600 call now
Old Jun 27, 2003 | 11:47 AM
  #64
NYVForce's Avatar
speedwerx I put the green spring in last night with 56 and 58gram weights and it has to muck stall it engages at 2800rpm on my tach. We need a 15 engagment and a 155-165 shiftout.
Old Jun 27, 2003 | 01:02 PM
  #65
BigOne's Avatar
I was talking to nyroc last night at my house about the green spring, I did not like it either, I took it right back out and whent back to the stock spring. WOW 2800 rpm engagment it did not feel like it. I guess my rpm butometer is broken[img]i/expressions/face-icon-small-smile.gif[/img]
The green spring engagment is to harsh. and the disengagment slams the clutch back against its stop.
If someone knows the lenght of the spring when it engages and when shiftout happens I can call a few places about getting spings made for us. They can make springs in fast ,1 to 2 days I just need more info to give them.
Old Jun 27, 2003 | 01:32 PM
  #66
TEDDY700's Avatar
WELL WONDER IF I COULD RETURN MINE AFTER I GET IT CAUSE IT LOOKS LIKE I WASTED 35 DOLLARS ON THE GREEN SPRING.....CAUSE IF IT ENGAGES THAT HIGH ITS ALMOST LIKE THE YELLOW I HAVE
Old Jun 27, 2003 | 01:39 PM
  #67
TEDDY700's Avatar
HEY NYVFORCE HOW WAS THE ENGAGEMENT WITH THE GREEN VS THE YELLOW WE HAVE? WHAT WAS THE YELLOW SPECS?
Old Jun 27, 2003 | 01:46 PM
  #68
prairievenom's Avatar
NYVFORCE i dont get why you want a lower engagment then stock i think a 25/150 would be a good spring
Old Jun 27, 2003 | 02:22 PM
  #69
NYVForce's Avatar
Because I think they make the springs to stiff I don't think the numbers really reflect what the spring will do I bought the hotseat green at 35-145 and it stalled till 2800rpm almost identical to epi's red at 59-145 I've tried probably 8 different springs in the v-force and and I think we have to ask for a very low engagement and a medium shiftout 150-165 range. I think the new epi pink will probably stall at about 1500-1800rpm depending on weights in the machine. And I still think that will only be the best out of a pour selection of springs. The manufacturers are used to making springs for polaris that engage gradualy the V-Force engages very suddenly EPI is the only companie that has worked on the v-force and I think that was rushed out only to be first on the market without enought thought put in it. They obviously realized this since they are making the pink spring but I think that it is only from customer input not actual R&D. A company has to get there hands on a few differently modified V-forces to come up with a few different kits because installing the dual exhausts and doing airbox mods totally changes the powerband in the V-Force from what it is stock that not one size will fit all when it comes to clutch kits for the V-Force. And just wait till we get CDI's that will change everything all over again hopefully the CDI makers realize we will need clutch kits to take advantage of the CDI a produce them or sub them out but that will only make the CDI longer to be released. I think I will see a unicorn before I see a CDI.
Old Jun 27, 2003 | 03:19 PM
  #70
TEDDY700's Avatar
HEY NYVFORCE I HAVE SOME QUESTIONS ABOUT THE AIRBOX MODS. I UNDRERSTAND ABOUT DRILLING THE HOLES AND REMOVEING THE SNORKLE BUT I DONT GET THE RADIATOR HOSE PART
