About Belt Shims
Old Oct 7, 2003 | 11:08 AM
AlbyKawa's Avatar
Default About Belt Shims
My belt is loose.
Based on what I can see opening the CVT, in the Primary Pulley (the one in the front), there is a space in between the Belt and the Pulley. This space can not be eliminated by removing a shim from the Secondary Pulley. I therefore believe that I need to add a shim in the Primary Pulley.
Am I correct? How can I open the two sheaves of the Primary Pulley?
Many thanks for your help.
Alberto.
Old Oct 7, 2003 | 11:14 AM
newbeatle's Avatar
you need to remove a shim from the rear pulley, to allow it to go together tighter... check NYROC'S website for full information, & tools required... WAM
Jeff Roper
Feb 1, 2022 11:48 AM
buddieboy
Dec 9, 2016 05:50 PM
Jeff Roper
Sep 21, 2015 02:11 PM
Ridgerunner665
Sep 15, 2015 01:20 AM
roy.hawkins3@gmail.com
Sep 11, 2015 02:35 PM
