P-360 Initial startup problems
Old Dec 3, 2003 | 12:02 AM
grizzlytim's Avatar
Default P-360 Initial startup problems
Try turning the screw out, I think this is all you need. The screw is on the bottom of the carb right in front of the fuel bowl, it is hard to see. The hour meter is part of the optional speedo.
Tim
Old Dec 3, 2003 | 11:42 AM
TxRebel's Avatar
SHould I try the air screw or the exhaust valves? I have heard both mentioned here.
TxRebel
Old Dec 3, 2003 | 01:16 PM
grizzlytim's Avatar
Try the air screw first, It only takes a few seconds to do.
Old Dec 3, 2003 | 04:10 PM
TxRebel's Avatar
Is there a screw on the fuel bowl also. I unscrewed a screw that I thought was the air screw and gas ran out. Was that the wrong screw. Also, I checked my air filter and noticed oil in the case. What the hell is this?
TxRebel
Old Dec 3, 2003 | 04:16 PM
  #15
MikeyBoyesq's Avatar
Oil in the air box is not uncommon. It usually occurs on the P650 when too much motor oil was put in the engine. Appearantly, there is an overflow tube/breather tube that dumps excess motor oil into the air box. Its usually no big deal. Just clean out the air box and air filter and try not to over fill the motor with oil in the future.
Happy trails...[img]i/expressions/face-icon-small-smile.gif[/img]
Old Dec 3, 2003 | 07:54 PM
  #16
grizzlytim's Avatar
The screw you removed is just a drain. The air screw is just in front of the bowl. You can not see the head of the screw with out turning the carb sideways or with a small mirror. If you use a small screw driver you can feel the head of the screw. Good luck Tim
Old Dec 3, 2003 | 07:57 PM
  #17
Uinthas's Avatar
You unscrewed the wrong screw.. the air/fuel mixture is right in front of the fuel bowl, its a little hard to find & requires either a special tool or a real small short screwdriver (I use a small standard screwdriver bit) .. The exhaust valve needing adjustment is a VERY COMMON problem on the 360 & does cause the engine to die when the ATV comes to a stop. But richining the air/fuel might be a problem as well..
Old Dec 4, 2003 | 08:49 PM
  #18
TxRebel's Avatar
Thanks guys, I will try that.
TxRebel
greg74
Sep 10, 2019 03:03 PM
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
