Prairie 700 "summer" oil
Old Jan 24, 2004 | 08:01 PM
rutwad's Avatar
Default Prairie 700 "summer" oil
I plan to change my oil to either Amsoil or Mobile 1 synthetic when weather starts to warm up. What is the best weight to use for the hot summer months. My prairie only has 20 hours. Is this too soon to change to syn.?
Old Jan 24, 2004 | 08:28 PM
WoodsRuner's Avatar
I am sure there will be disagreement, but I have always heard wait till 100 hours before
using synthetic oil. I believe syn oil is supposed to be thinner than petrol oil, so go heavier
I assume?
Old Jan 24, 2004 | 08:43 PM
DaRiot's Avatar
Am in the exact same situation here. Want to go synthetic but not too soon.
Old Jan 24, 2004 | 10:16 PM
peteyz24's Avatar
woodsrunner its not 100 hours but 100 miles
rutwad, amsoil makes a atv specific 0w40 that is made for all year round usage, this is what i plan on putting in my quad the next time i change the oil, they also say that you can run the oil twice as long as the standard oil, but you do have to change the filter at regular intervals
Old Jan 25, 2004 | 01:38 AM
Wires's Avatar
You need to run it a bit to allow the engine to break in. Problem with synthetic is it's a really good lubricant. Almost a little too good, since it'll inhibit break in. If you don't let the rings seat with regular oil, then you can have oil burning problems in the future.
Just use the normal weight you'd use in the summer (see your owners manual). Usually 10W30. You could probably run a straight 30 oil (like a lawn mower oil), but what tends to happen is your too stupid to remember to change it out as the temperatures start to drop, run it a couple of times in colder temperatures (which causes major accelerated wear). Not that I've did that in the past, of course! [img]i/expressions/face-icon-small-smile.gif[/img]
Be wary of using oils like 0W40 all year around. The wider range they are, the more additives are used to keep them stable. They have to work harder at the extreme temperatures, and tend to break down faster.
ReconBayou
Oct 16, 2019 02:24 AM
hueby
Nov 6, 2015 11:34 AM
PrairieDog126
Sep 12, 2015 05:23 PM
coolguy420
Jul 10, 2015 01:17 AM
coolguy420
Jul 9, 2015 09:54 PM
