p700 belt explosion HELP!!
Old Feb 18, 2004 | 02:55 PM
kawtech's Avatar
Default p700 belt explosion HELP!!
not sure what a pm is or how to send a private message cant find a padlock??
Old Feb 18, 2004 | 03:10 PM
newbeatle's Avatar
KAWTECH... a PM, is a private message, & in the upper right corner of each members post, is a few icons ... click on these to explore a bit ... the head with the ? will give you more info about that member... the padlock in that menu will set you up to private message someone... if that forum member has a camera at the left of thier post, clicking on it will bring up more information & pictures that that forum member has set up to view... hope this helps...
Old Feb 18, 2004 | 03:19 PM
trx450's Avatar
raptor 101000000---- You DID check to make sure ALL (4) of the helix pins(hard to install little b@stards) were in their slots , right? Man , THAT must have been interesting; seeing the spring ricochet off the ceiling!
Old Feb 18, 2004 | 08:41 PM
Raptor010101's Avatar
TRX,
I am guessing your talking about the 4 little button type pins that go inside the center??
if so i got them all in. Was easier than i expected for once.
Old Feb 19, 2004 | 08:06 AM
  #15
trx450's Avatar
Yep , the 4 (little b@$tard pins, or buttons) that ride in the 4 helix slots. Have fun!
Jeff Roper
Feb 1, 2022 11:48 AM
buddieboy
Dec 9, 2016 05:50 PM
hueby
Nov 6, 2015 11:34 AM
Jeff Roper
Sep 21, 2015 02:11 PM
Ridgerunner665
Sep 15, 2015 01:20 AM
