Turning that "old" 650 Prairie into a ripper...
Old Feb 20, 2004 | 10:22 PM
  #31
Customfabandweld's Avatar
Default Turning that "old" 650 Prairie into a ripper...
Oh, by the way, I had no trouble with the hills. I don't notice the low end power drop off, unless I'm taking off from a standing start.
Old Feb 21, 2004 | 02:35 AM
  #32
MikeyBoyesq's Avatar
Customfab,
I was wondering if you have a holeshot module on your quad? If you don't already have one, you should consider getting a module OR the new Dyna cdi to see if that brings back your low-end torque. Just a thought.
Happy trails...[img]i/expressions/face-icon-small-smile.gif[/img]
Old Feb 21, 2004 | 03:31 AM
  #33
I will do the timing key, soon. I can't afford the new CDI, yet. I was riding some dirt roads around 55 MPH and you can punch it and still spin the tires! I can't believethat it's doing that through the stock muffler and air cleaner. Man, when I get it to breathe...................[img]i/expressions/face-icon-small-shocked.gif[/img]
Old Feb 21, 2004 | 07:56 AM
  #34
NovaKaw650's Avatar
Originally posted by: Customfabandweld My top speed went to 69 MPH. I can't wheelie in high without pulling on the bars
That's a symtom of the 20 degree cam timing change, the couple of guys that I know that have 10 degrees retard can flip it upside-down at anywhere from 2 to 20mph. The timing key will help a little, so will a stiff, high stall primary clutch spring. Do you have a module?
Old Feb 21, 2004 | 02:25 PM
  #35
No module. I really don't care about the wheelies, although I love to do it, because on dirt all it does is spin, anyway. The trade off for the power a little further up the RPM band is worth it for me. I won't spend the money for the module, I'll save for the CDI. How much is it going to be, anyway?
Old Feb 21, 2004 | 11:06 PM
  #36
tuffEnuf's Avatar
The red EPI driven spring should cure your takeoff woes.[img]i/expressions/face-icon-small-happy.gif[/img]
Old Feb 21, 2004 | 11:12 PM
  #37
tuffEnuf's Avatar
What are the 11:1 going for a pair? Whats all included with price and will engine have to be bored?[img]i/expressions/face-icon-small-cool.gif[/img] Or will it just need honed and last are New pistons heavier than stock?
Old Feb 22, 2004 | 01:35 AM
  #38
MickeyDunlap's Avatar
$100 each,just hone.
Old Feb 23, 2004 | 12:44 PM
  #39
Crankdog's Avatar
Customfab,
could you tell me in more detail how you retarded your cams. I am thinking about doing it as you did, but don't have a manual. If I have to I can buy one, but what exactly did you do when you got in their, which way did you rotate the cams, etc. Also I thought this was an interference motor, but obviously you have had no problems, right, as long as I don't end up with bent valves, this sounds like a go to me. Any info you can give me would be great. Thanks in advance.
Adam
Old Feb 23, 2004 | 12:46 PM
  #40
Crankdog's Avatar
Customfab,
One more quick thing, did this affect your dial-a-jet setting, I also have them.
