dyna cdi makes motor kickback when starting.
Old May 13, 2004 | 12:30 PM
  #171
MikeRhyne's Avatar
Default dyna cdi makes motor kickback when starting.
After reading all of these posts again I just ordered a DG3. I don't want to mess with having my quad have problems and I could care less about more top end - only hit 50 once so far and that was a rare stretch of open road for my rides.
Old May 13, 2004 | 01:10 PM
  #172
04kawasaki700prairie's Avatar
alltoys i will keep you guys posted on what happens.Dynatek is sending me a new cdi when i get quad back from shop and try it i will post what happens. Good luck to all.
Old May 13, 2004 | 01:47 PM
  #173
KISSSOFDEATH's Avatar
And mostly good luck to you 04kawasaki700Prairie.
Old May 13, 2004 | 02:29 PM
  #174
thanks kissofdeath.
Old May 13, 2004 | 03:15 PM
  #175
prairie633's Avatar
Maybe Dyna's circuit doesn't do some of the important stuff that the stock one does. Why would it be less reliable just because it fires the plugs a little sooner after 1500 RPM? Did they change the start-up sequence? Maybe someone with a bad one that misfires frequently can send it to Alltoys to look at, just a thought?
Old May 13, 2004 | 03:42 PM
  #176
BrilliantBloke's Avatar
Maybe someone with a bad one should send it directly back to the manufacturer (Dynatek).
Dont send the CDI to someone else other than the people that made it.
Old May 13, 2004 | 05:47 PM
  #177
Mine is gone. I sent it back to Dynatek today. Im asking for a full refund not a test.
Old May 13, 2004 | 06:03 PM
  #178
prairie650's Avatar
I'm glade that I waited, I think I'm going to get the DG3 after all this talk I think they missed somthing, has anybody used a DG3, what will it do for a stock 02 650.
Old May 13, 2004 | 06:19 PM
  #179
newbeatle's Avatar
If you ask Don, he will tell you that there are differences in performance with the DG-3, between the '02 model & the '03-'04, because of differences in the stock CDI... It will outperform anything out there currently available, except the Dyna CDI... but so far shows no signs of the problems plagueing the Dyna unit... it has been tested in several Baja races, it is not like the "other" standard bottom end modules, it hooks up to both ends of the pink wire, it comes with a 5th wire, & easy directions for installing a switch ( color dirrections no less )... it is potted in clear stuff, so that you can see the processor, that is not in the other modules... it contains 5 LED's, for diagnostic purposes... & as good as the DGR Hole Shot Module was, it provides even more bottom end, mid range power, & some more top end power... it will not disable any of the stock CDI's safety features, or raise the rev limit, & you will likely not see any more top end, but it will offer the strongest bottom end, & mid range power availble... I believe that Don recommends a timing key, for very similar performance benifits to the CDI...
Old May 13, 2004 | 08:31 PM
  #180
And I have determined that the degree key is something I wont be needing. Also, I dont mind cutting wires for something that will work the first time around.
