anyone having vforce front end problems?
Old 05-20-2004, 12:00 AM
2TV's Avatar
2TV
2TV is offline
Default anyone having vforce front end problems?
There are other solutions available if you keep having trouble with your tie-rods. Check out this thread from an earlier posting on this forum. Note however by strengthening the tie rod, you may increase the risk of bending or breaking some other part, however I have not noticed anybody having trouble after putting the stronger tie rods on…
Old 05-20-2004, 01:11 AM
mabell1's Avatar
i bent my tierod 3 weeks after i had it. i have since replaced it with the stock ones and have yet to have one bend again (its been a couple of months) you can find stronger aftermarket ones on ebay. but for $7.00 a piece i would rather stock up on stock ones and have to replace them every once in a while then spending big bucks when your tierod wont bend. plus it only takes a couple of minutes to change one. jmo!!
Old 05-20-2004, 12:42 PM
mt's Avatar
mt
mt is offline
I have replaced my stock tie rods, I think new stronger ones were $30,?? def. check toe in, tire pressure, also have a Denton steering damper that helps.
WilliamBos
09-30-2015 08:08 AM
Stillonit
08-05-2015 07:46 PM
scaldwellk
06-19-2015 05:08 PM
blaze_master
05-26-2015 11:18 AM
Quick Reply: anyone having vforce front end problems?
