2004 kvf700 sputters and won' gain power
My 2004 kvf 700 starts and idles good. As soon as you get to about 30km. the motor won't gain any more power and starts to break up.The rear cylinder is the one that breaks up if i just run one at a time.Both cylinders have good compression,spark and fuel.I have checked every thing i can think of but can't figure it out .HELP!
Just FYI
P700 does have a limp mode. Mine was doing the same thing about 2 weeks ago. I tried several times to reset the belt light but to no avail. Paid my dealer $18some dollars to tell me that the machine was in limp mode because the belt switch needed to be reset.
Oh and I did turn the key on with the CVT cover off.
Live and learn
Live and learn
There are only 86 hours on 700. I have reset the belt switch 3 times but does not help. It has fresh fuel yesterday new spark plugs.Tried new coils a new igniter a new tip over sensor checked carbs and set them up with a mercury carb stick.Both cyls run.There are no mods done completely stock.All connections are good. What is limp mode.Is that when belt switch needs to have its memory cleared.Because i have done that.
