My 650 won't stay running
you can try unscrewing the gas cap... if it continues to run like normal, with the cap off, then likely your tank vent line is plugged... if it continues to die, then it is likely the fuel pump / regulator, that is inside the gas tank... I believe there is a prefilter on the fuel pump pick up, but your tank would have to be pretty nasty, for that to be a problem... BTW... welcome to the forums...
whitty
67
02-24-2021 02:52 PM
