Mojave shock adjustment
Old Feb 28, 2005 | 08:06 PM
Poster's Avatar
Default Mojave shock adjustment
I recently went ridin at Flat river in Missouri and after riding my mojave awhile i decided that my shocks were really stiff. landing jumps was kinda painful at times. I hate to mention the 300ex in this forum but i would like to make the suspension perform like it off of jumps. In other words i want a softer ride. Do i need to loosen the shocks to make it softer or tighten them. If not possible, then what shocks do i need to put on this bad boy to make it softer on my *** when i land a jump.
Also i heard that a 250R shock bolts right up. How much do those cost?
Also i just got some new tires, they are called strykers, kinda like a wooley booger with turf **** on the outside. they are 22x11-10s, a little wider than stock and then im puttin on a 13 tooth front sprocket.
then one day a pipe and jets...
this will be a machine when i get done.
Old Mar 2, 2005 | 06:05 PM
rolsmojave3's Avatar
i would look for some Works or Elkas for the front...but the 250R rear shock will fit on the rear of the mojave with a little mod to the spacers
Old Mar 2, 2005 | 08:54 PM
Poster's Avatar
rolsmojave3,
works or elkas huh? i will look at them. As for the 250R rear shock...how hard is it to mod it? Also do you know how the mojo will perform with stock tires and a 13 tooth front sprocket?
Old Mar 2, 2005 | 08:58 PM
the 13 and stock tire will pull the bottom end away a little but not too bad...just harder to wheelie when going slower...you just have to grind off the spacers on the bottom shock mount to make it work
Old Mar 2, 2005 | 09:05 PM
Poster's Avatar
well i would like to be able to pull a wheelie in second. but i think the gain in speed would be nice.
Old Mar 2, 2005 | 09:41 PM
Poster's Avatar
Do you know anything about engine upgrades...like the 330 kit???
Old Mar 2, 2005 | 10:49 PM
i hear that they are really worth it and CWR has them
Old Mar 3, 2005 | 11:16 PM
Poster's Avatar
Do you know how much they cost....that might be a good winter project for next year. I cant find anything on them on the net. Do they have a website? I would love to get this thing hopped up a bit so i can run with some of the big dogs.
Old Mar 3, 2005 | 11:18 PM
cycleworksracing.net
Beeline08
Nov 11, 2016 04:00 PM
Scooter's Shop
Oct 9, 2015 02:09 PM
r1pilot83
Sep 27, 2015 07:38 PM
cboler9
Sep 24, 2015 08:35 PM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
