Does My Mojave Have A Broke Ring?
Originally posted by: DeuceRooster
I have verified that the only place that the oil is leaking from is the drain tube, it's a clear one thats comes out of a black box that IS behind the airbox, next to where the rear shock top mount is. What exactly is that box for?
The box that it's connected to is part of the emission system. The crankcase is vented into that box. All engines will have some blowby and the blowby carries oil into that box and they put that clear hose with a plug in the bottom to drain that box.
Your sposed to pull that plug out and let it drain every 3-5 of ride time. Once the rings get seated you won't get as much oil in the box.
