Quad refuses to shift into 4th.
Old Jan 14, 2006 | 05:46 PM
kherman123's Avatar
Default Quad refuses to shift into 4th.
Hi. I have a 2003 Kawasaki KFX400. It will not shift up from 3rd gear into 4th gear, or down from 5th. When you try to shift into 4th gear, it just goes into neutral. But when you try to shift either up or down from the 4th gear position (which is just neutral) it goes into 3rd, or 5th, depending if u shift up or down.
Also, the bike has a terrible metal on metal click coming from inside the engine when running.
Does this sound like a clutch problem? Or worse?
Old Jan 14, 2006 | 06:21 PM
stewbing's Avatar
you broke 4th time to tear it down and fix it
Old Jan 14, 2006 | 07:02 PM
kherman123's Avatar
you say i broke 4th. okay, are you saying i broke the 4th gear plate inside the clutch basket?
Old Jan 14, 2006 | 08:27 PM
stewbing's Avatar
nope eather a shift fork or the gear you will need to split the cases in otuer words its got to come completly apart
Old Jan 15, 2006 | 12:32 PM
powerismygame's Avatar
Yup! wile your in there do some motor work[img]i/expressions/face-icon-small-wink.gif[/img]
Fred
Old Jan 15, 2006 | 12:58 PM
kherman123's Avatar
Ya, well the bike was gonna get hooked up on motor work from my tax return. That money got cut into a little bit...
Frisky2050
Apr 9, 2020 11:19 AM
Captjay
Jul 23, 2015 12:33 PM
KimSJoh
14
Jul 18, 2015 07:20 PM
Scottma518
Jul 16, 2015 09:19 PM
sara durrant
Jul 6, 2015 05:32 PM
