Battery Amp hour how much is enuff?
If you are buying a new battery get the same size as original. It will start the engine reliably if you are doing a lot of short runs. The ignition is worked from the battery on the 300 so you need battery power to start. Those little Kid's quad batteries don't seem to last long, and will go flat sooner if the bike is laid up.
