So replaced the crank (Big bearing on con rod was completely gone) discovered the oil pump had broken so replaced that, all back together and I managed to get it going! After a lot of trying. Sounded brilliant whilst it was idling and going through the gears.
Then I went to start it the next day and now it’s so slow to crank and drains the battery very fast and also the starter motor gets very hot whilst trying to start, so replaced the battery, solenoid, all the starter circuit leads. Still the same issue!!
I have a new starter motor on order so hopefully that will sort the slow crank out.
Sounds like starter motor spinning and not turning engine. Can't remember if those starters have the built in reduction gearbox, but if they have, it could be that gearbox gone, but my guess would be the one way clutch on the flywheel. I know it is new, but did you re-install it properly?
ye all installed correctly, I’m convinced it’s the decompressor on the cam shaft. Please see video below and let me know what you think! I tried a brand new starter and I got the exact same issue.
Afraid I don't know enough about the KLF decompressor to know if sideways play matters or not. Still convinced the starter motor is spinning a lot faster than it is turning engine, if so, it is loosing drive somewhere. Though noise from starters can be deceptive, Arrowhead replacement starters on Honda 420s make a similar amount of noise but work fine.
please see photos on my rocker arms, do you think they are excessively worn and could this affect the starting of the engine Exhaust rocker Intake rocker
As I wrote, your starter clutch or the gears to the clutch are slipping, not entirely sure that bolt should be wobbling about as the engine turns either, are you sure the main bearings are OK? Take the alternator case off again and try to work out what is wrong. Cam followers are shot, check the lobes on the cam too as they may be worn. Workshop manual will tell you what size the lobes should be.
