drain for the belt?
Old Apr 8, 2003 | 11:07 AM
nyroc's Avatar
Default drain for the belt?
Some guys have drill and threaded a 1/4 coarse thread and put a really short bolt with a rubber washer in the hole.
Others buy a Grizzly 660 drain and use that (drill hole).
One guy installed a petcock.
I got a lot of water in mine once. revving it in neutral worked, but took a while. If I got water in my belt more often, I would probably use the screw and rubber washer idea.
Old Apr 8, 2003 | 11:22 AM
SASCACH's Avatar
The new 700s have a drain, might be comming out on the new 03 650s.
Old Apr 8, 2003 | 12:15 PM
TriumphDude's Avatar
I like to remove the cover and dry the belt completely, so it won't
slip. It takes a minute to remove the cover. Belts are not cheap. I am
going to snorkle the intake and exhaust, can't stay out of the water. I
drowned out the other day, I guess it was water coming back the exhaust
at idle. It was slugged, I should have jumped off, as it floats a little.
I could have kept it running. I floated it back to shallower water and
pulled the filter cover to look for water. It was fine. I then started it
and rode out, then pulled the primary cover and dried it out. There was some water in the oil, so I changed it when I got home. I will change it
after another hour of running, to make sure it is all out. No big deal,
I don't think I did any real damage.
ReconBayou
Oct 31, 2022 05:37 PM
Jeff Roper
Feb 1, 2022 11:48 AM
wrencher82
Sep 30, 2015 04:27 AM
wrencher82
Sep 28, 2015 10:02 PM
wrencher82
Sep 24, 2015 03:39 PM
