P650 manufacturing problem or human error?
Old Apr 14, 2003 | 03:12 AM
Ginchy's Avatar
Default P650 manufacturing problem or human error?
Take an ATV riding class, I was having the same problem as you, until I took the class, they went through deep breathing techniques and a little secret, dont tell anyone, pour some starch mixed with rubbing alcohol on your hand and place it in a dryer for one and a half ours, this should cause some shrinkage, is this post for real, or is this a ribber, if your post is for real, then alltoys is very much TRUE,
Old Apr 14, 2003 | 09:24 AM
NovaKaw650's Avatar
The throttle position is movable. Maybe your's is too far under the grip. If so, loosen the screws holding the throttle assembly in place and rotate the throttle towards you. This will put it further away from your index finger.
Maybe the bars are tilted too far back; that would give you the same effect as the throttle twisted too far under the grip. [img]i/expressions/face-icon-small-confused.gif[/img]
Old Apr 14, 2003 | 11:21 PM
robh's Avatar
I had this very prob happen to me, but i was using a throtle extender at the time, i promptly took it off, havent had the prob since
Old Apr 15, 2003 | 01:59 AM
alltoys's Avatar
Nova is right you can adjust the throttle position although if this dosen't work try very slowly to bend the throttle down with a short piece of pipe on the end of the lever. Did you really need that index finger......LOL. Try one of the above remedies I am sure you can find a fix almost sounds like it was bent earlier from who nows what.
Old Apr 15, 2003 | 01:24 PM
  #15
SASCACH's Avatar
I know exactly what your saying rutwad, this happened to me once when I was wearing a heavy glove, just about put the 650 over backwards. I gota agree I'ts where your holding your hand on the grip.
Old Apr 16, 2003 | 10:22 AM
  #16
rutwad's Avatar
It is not the normal way I grip the handlebars, but I guess sometimes I change without notice. Scared something similiar may happen again, so I do plan to bend the throttle lever down to increase the gap between it and the grip.
Next time I may not be so lucky.
Thanks for the info
lightninboy
May 16, 2021 09:52 PM
Nondem
Where to Ride
Jul 23, 2015 07:38 PM
Captjay
Jul 23, 2015 12:33 PM
KimSJoh
14
Jul 18, 2015 07:20 PM
toonces
Jul 15, 2015 07:14 AM
