lt80 stall speed
Old Sep 21, 2005 | 10:15 AM
Cougar205's Avatar
Default lt80 stall speed
Well got the new clutch parts in last night.Man got the top speed back! put just 4 rollers back in.I'm I going to see a big difference in stall speed.Maybe i'm expecting to much. Also has anyone put a filter on the clutch cooling intake so it actually gets filtered air? Other than that it seems to run great,so off to the dunes Friday !
Old Sep 21, 2005 | 11:43 AM
LT80's Avatar
LT80 Expert
Removing 2 rollers helps stall slightly. This should help in the dunes.
A filter on the clutch air inlet is normally used when ppl go to the 20mm carb. The stock air routing works fine.
Pehter
Oct 3, 2024 11:00 PM
QuadRiders
Oct 22, 2015 04:13 PM
ReconBayou
Sep 23, 2015 02:41 PM
merryman
Sep 19, 2015 03:15 AM
Jaymc
Sep 11, 2015 07:45 AM
